"Bedding" period for new clutch??
I just had the clutchplate and pressure plate replaced on my 997tt (standard clutch etc from Porsche). It has the Switzer P700 package done. The previous clutch lasted 12000km, although after only slipping once, I decided to replace it with a new one. The shop that replaced the clutch told me the previous clutch was only about 50% worn and wasn't really nescessary to replace. When I picked up my car the shop owner told me he testdrove the car and the clutch slipped under load... I asked but shouldn't it be bedded in first before hard acceleration and he said yes, but looked a bit puzzled as to why it slipped. (flywheel was replaced with previous clutch replace and was in very good condition, so not replaced now)
I am going to SA Speedweek end of April and don't want issues.
So my question is how long should a new clutch be bedded in for (kms) and is there a specific way or will normal city driving be fine?
100% oem pressure plate that can not handle the power. get a Sachs 764 PP
^ As he said. Sachs 764 PP is needed 100%.
Stock C & PP will never hold a 700 tune at WOT especially on a used flywheel. If these guys knew you had a tune then why on earth would they advise to fit another stock clutch? If they said they had no idea why your old clutch was slipping, least of all the new one is a bit of a worry or weren't they aware of the 700 tune?
I had a stock clutch since the 700 tune and it has been holding fine for about 8000km of heavy use. It slipped once a few weeks ago and then I thought it was toast which was not the case. I drove the car another 2-3weeks trying to get the clutch to slip again and it didn't, but I got it replaced anyhow because of the Speedweek coming up. Now the new clutch is slipping..... my thoughts are just to let it bed in properly and see how it goes. The previous STOCK clutch held fine for hundreds of pulls, just slipping once
Pedal is same but feels better in take up. If your stock clutch doesn't slip then i doubt you have anywhere near 700.
I did tune/exhaust only and was slipping almost immediately. Sachs stage 2.5 takes a little getting used to. It grabs more aggressively and in my case at low pedal position..... so basically had a few embarrassing stalls early on with it. Handles power well though
Well it is the Switzer P700 package, only have a different exhaust Europipe Stage 2, so might be slightly less than 700hp, but remember that is not whp, it is on the flywheel. Switzer even said no clutch upgrade neccesary but recommended it. Anyway thanks for the info! Appreciated!
Mine also slipped after only a few WOT pulls and my car had under 5000kms on from brand spanking new. When the clutch was removed it looked new too, but it had been slipping as evidenced by the burn marks on the surfaces. One things for certain, the Protomotive tune puts out its claimed power of @ 500+....no question about that. The OE clutch serves as concrete evidence of that.
^^^^^ Speed I hear you but there are lots of guys running various tunes with 500+ on stock clutch. I was in Phillip's car and he's got 550hp+ and runs the stock clutch and IIRC he put 20K miles before he said he felt it slip for the first time.
could there be variability in the stock clutch from car to car, hence some guys feel an immediate slip with a 550hp-600hp (crank hp) tune and others can run 10K, 20k+ without experiencing any slipping?
ECS Tuning - BMW
09-16-2015 07:20 AM
ECS Tuning - VW
09-09-2015 03:11 PM
ECS Tuning - VW
09-09-2015 12:01 PM
ECS Tuning - VW
09-03-2015 09:43 AM
