Boost Error P3802
Boost Error P3802
Hi guys,
I have what sounds like a boost leak. I am getting the error code P3802 Turbochargerboost sensor "A" circuit high Upperlimit value exceeded.
I have re-seated all boost hoses and Y Pipe, but it is still there.
Does anyone know which is sensor A? I am hoping it may help me identify the fault.
Hi guys,
I think you mistyped the code. The code should be P0238 IMO. You get this when the boost pressure sensor signal is above the predicted range.
Possible causes:
- Boost pressure sensor harness is open or shorted
- Boost pressure sensor circuit poor electrical connection
- Faulty boost pressure sensor
- Faulty Turbo/Super Charger
- Engine over temperature
- Ignition misfire exceeds the calibrated threshold
- Faulty Knock sensor (KS)
Hope this helps.
Hi,
Possible causes:
Hope this helps.
Possible causes:
Hope this helps.
There is a very distinct boost leak sound.
Does your car misfire at all? Especially at idle.
The idle drops a bit low after decal, maybe 100rpm. Otherwise it drives OK. It leaks boost when it gets to 15psi, and is down on power.
After I pulled it apart and put it together, it drove fine with no leak for a few boosts, before returning.
Can a faulty boost sensor cause it to vent boost?
Yes it is Durametric.
Have a look at your MAF sensors also. They might be getting a wrong signal. When there's a leak you often hear the blow off valve really loud. The most critical points are the Y-pipe where the TB is and the intercooler hoses. They could be loose. But since you double checked them I would think that one of the sensors has a poor signal or receives faulty information.
TT Crab. It looks like you were correct. Durametric reports the error wrong. It is P0238 according to Porsche. They also believe that the car is overboosting, which is triggering the diverter valves to vent the boost.
Now we have to work out why. Hopefully it is the boost sensor itself.
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
