Rear Uneven ride height HELP!!
Old 06-02-2013 | 01:59 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Sure sounds like you have very capable people working on the car. Last thing I would check is to see if the shock mounts haven't been reversed or something. I haven't working on the Porsche yet but when I did my M3, there was a forward facing pin which fit through a guide hole. If you didn't have it correct like I did. This pin would impede a flush install to the shock tower and could produce a gap of 5-6 mm. Not to mention could screw up your castor.
Old 06-02-2013 | 04:34 PM
RedMile's Avatar
RedMile is a jewel in the roughRedMile is a jewel in the roughRedMile is a jewel in the rough
had this issue when i went back stock (my TT was on H&R ) and i tried almost everything no luck
so i just went with a set of bilstein coilovers with H&R sway bars verdict car much much better in handling and ride quality was superior and more sporty than stock
the disadvantage was activating sport mode wouldn't do that much really lol almost same without it, telling or feeling any difference is hard (at least to me )
hope this help
Old 06-04-2013 | 12:17 PM
cannga's Avatar
Originally Posted by TT Surgeon
10mm variation per corner is within spec for ride ht on a 997.
Thanks. Wow that's a lot considering how big of a change 10mm is. I was thinking maybe 5-7 mm.
Old 06-04-2013 | 04:26 PM
TT Surgeon's Avatar
Those are stock/OEM parameters.
Old 06-04-2013 | 07:26 PM
slawek's Avatar
slawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond repute
yeas Cann ,
on stock suspension our turbo can have up to 10 mm. from side to side deference.It is a factory tolerance.Everything it's constantly changing- amount of fuel, weight of the driver etc,All four springs in "stand by position" are not exactly perfect and identical ,specially when a car has some miles on it .Once you put some stress on them while driving the difference between them minimize . In other wards if we could measure our car hit while driving 55 mph. it probably will be perfect on four corners.
Old 06-04-2013 | 08:46 PM
cannga's Avatar
^^^Thanks.
Old 06-05-2013 | 06:44 AM
DNugget991GT3's Avatar
its probably not the springs at all.
its probably the ANGLE of your rear camber on that one wheel which gives the illusion that the car is sitting lower on one side than the other.
04-28-2022 12:38 AM
Vicelord
Ferrari
17
01-26-2017 12:50 AM
pshep138
09-01-2015 09:45 AM
tkeck3
08-25-2015 02:52 PM
08-19-2015 06:35 PM
Quick Reply: Rear Uneven ride height HELP!!
