Brake Dust...Are there any options to reduce it?
Old 07-14-2013 | 12:08 PM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
Question Brake Dust...Are there any options to reduce it?
Since my Gallardo has CCBs I never have to deal with brake dust. My 997TT on the other hand generates a ton of brake dust.
Aside from swapping out my brake system with CCBs are there other options?
Maybe low brake dust pads?
Tks
J
Old 07-14-2013 | 07:17 PM
Spatia's Avatar
Spatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to behold
Bump
Old 07-14-2013 | 08:50 PM
TighTT's Avatar
TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !
As you said...the only REAL solution is installing PCCB's.
Old 07-14-2013 | 08:59 PM
yumaverick's Avatar
yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !
Same problem here, my HRE's are covered in brake dust after a couple days.
Old 07-14-2013 | 09:05 PM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
I'd take a look at 22ple VM1 Rim and Metal Coating
Old 07-14-2013 | 09:11 PM
Spatia's Avatar
Is there a more reasonable way to go PCCB than OEM at $15k?
Old 07-14-2013 | 09:15 PM
TighTT's Avatar
Used OEM. Seriously.
Old 07-14-2013 | 09:19 PM
Spatia's Avatar
Where does one find used?
Old 07-14-2013 | 10:54 PM
Jeff SD's Avatar
What about a low brake dust pad? Is there such a product?
Old 07-15-2013 | 05:16 AM
Mumureo's Avatar
Mumureo is infamous around these parts
Tire Rack has Stoptech low dust brake pads for the front but not for the rear.
Old 07-15-2013 | 08:22 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Low dust pads typically offer less braking power and tend to be noisy. I would just apply wheel wax. It doesn't get rid of it just reduces the amount to an okay level.
Old 07-15-2013 | 08:43 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i tried the armorall wheel protectant or whatever its called, it works amazingly well, i was pretty shocked, 2 weeks of driving and barely any sign of brake dust
Old 07-15-2013 | 11:22 AM
DNugget991GT3's Avatar
i have ccb's and they dust. wtf ?
Old 07-15-2013 | 11:56 AM
RSS's Avatar
RSS
RSS is a name known to allRSS is a name known to allRSS is a name known to allRSS is a name known to allRSS is a name known to allRSS is a name known to all
On my BMW's I switched over to Akebono brake pads. You might check to see if they are available for your car. They do not dust at all.
Old 07-15-2013 | 01:48 PM
aa909's Avatar
aa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond repute
yup I did the same and almost no brake dust now vs the BMW OEM pads which are similar to the crazy amount of dust my porsche pads produce. but I have to admit the akebono's don't have the same initial bite that the oem pads have. It's definitely a trade off and I will likely go back to OEM pads for the superior braking power
Quick Reply: Brake Dust...Are there any options to reduce it?
