Sponsored by: Bears Transport
Tune w/ stock turbos. Need Help!!!
Old 07-30-2013, 12:28 PM
cannga's Avatar
Originally Posted by spoiled996
The guy doing the Dyno seemed to be a bit new at testing them. What gear should you do the pulls in, and at what rpm should you floor it?
To answer your question the dyno runs I've seen are WOT, 4th gear, from 2000 rpm or so.
More importantly, if you feel this way about the shop then it's probably a very good idea to stop using them for dyno runs.
Most importanly , if you have many questions about the tune, then you might want to get a Durametric cable. It would give you many answers regarding boost and power and you don't have to rely on someone else. Actually it will give you ALL you need to know about boost pressure, including peak boost, and boost curve. See the ECU tune link in my signature and bbywu's Durametric DIY thread at top of forum page. A Durametric dyno simulation run could be done in 3rd gear, WOT from 2000 rpm.
Old 07-30-2013, 01:10 PM
spoiled996's Avatar
spoiled996 is a jewel in the roughspoiled996 is a jewel in the roughspoiled996 is a jewel in the rough
The porsche dealer thinks the main problem is heat. Lack of cooling fans after an 1 1/2hr driving that am and then pulling from 11-1pm without fans on the intercoolers
Old 07-30-2013, 01:14 PM
Chkmgnt59's Avatar
Chkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud of
They dynod the car without dedicated fans on each IC? Yeah, that's your problem. The dyno chart is worthless, and honestly I'd ask for a refund b/c they completely wasted your time by not putting fans on the ICs.
COBB Tuning
01-29-2022 09:42 AM
The_Ruski_Driver
10-25-2015 08:40 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
BauerR
08-25-2015 08:58 AM
Quick Reply: Tune w/ stock turbos. Need Help!!!
