RE-11's vs R-888's and Gauge Stuff
The weather finally cooperated and I had an opportunity to run the new R-888's at the track this weekend. Whereas I had been turning 2:08's on the RE-11's, I managed a couple of 2:06's with the 888's and I think there's probably another second or two lurking within them. They don't provide the audible feedback the 11's do but they breakaway at the limits very predictably and overall the level of grip is certainly superior as one would expect. Definitely a step in the right direction.
Also installed an OBD2 gauge from Brockway Engineering that can monitor 23 different engine parameters and display 4 at a time. I chose Intake Air Temperature, Engine Coolant Temperature and Air/Fuel Ratios on Bank 1 and Bank 2. IAT's reached 170+ degrees and I'm not sure what is considered excessive. Any informed opinions would be appreciated while ECT's climbed to 232 degrees. Ambient temps were in the high 90's. What is interesting about this is the coolant gauge in the instrument cluster never budged above 175 degrees lending credence to the thought that it's a dummy gauge with limited real value. Eventually I'll have another sensor installed to monitor exhaust gas temperatures but that's another project for another day.
And what did you mean by the audible feedback please? More screeching noise with the RE-11 at the limit?
The 888's sidewalls are definitely stiffer so there is less roll. I think the 888's also have a somewhat more squared-off profile which helps as well.
The 11's howl and screech more at the limits. If they are not making a racket, they are not being driven fast enough! The 888's don't make much noise at all but when they start to slide, it is progressive and easy to correct and control. Not much drama and not bad for a tire that can be driven 225 miles to the track (provided it's not raining). Also, just as a benchmark, my GT3 buddies, who typically run Hoosier or Nitto slicks, lap in the 2:01-2:04 range. Best,
I have re-11s on one set and r6s on another. Have you ever run r6s? There is definitely an Audilble difference when at the edge between the 2. When the r6s are done, I want to try something like the 888s or nittos(not sure I can get 19s though). How about length (time) they are good before getting greasy? After 21 minutes or so, my re-11s get slippery.
Okay, now we need someone to report on the new Dunlop Sport Maxx Race tires : )
The set of RE-11's I bought earlier this year are still in outstanding condition. They have only seen 5-7 heat cycles...although I think I am on my third set of R6's.
Once these RE's are done, I think I might try the Dunlop's because when things are wet I run the RE's. Not too sure if the 888's would be the best choice for a rain tire/DD tire.
Thanks for sharing Steamboat!
Bob, do you know any other specific levels where the ECU steps in? I really do appreciate not having to replace/rebuild another motor but it sort of defeats the purpose of being at the track when it's hot and whatever else. Thanks,
We ran 25 minute sessions and I didn't particularly notice the 888's getting greasy per se. Now, if you take an early turn in and come in a little hot, they are happy to slide around towards track out. But as I said before, nothing too dramatic. I agree with your assessment on the 11's; about 20 minutes in hot weather before they go away. Best,
It's hard to say - I am not familiar with what EVOMS does to the programming - typically the car will pull timing, pull boost, or run richer when IATs climb excessively. When I'm at the track, I usually run 50/50 93/superjuice for a margin of safety.
Thanks Steamboat and co. First sensible discussion on tyres I have come across in a while. I agree RE11s good grip, nice tyre. However on hot roads and hard driving (within 30 min) they get too soft and the rubber gives, then the back tends to slide. I can't understand people's faith in Michelin MPSC tyres these just let go on the edge. I can't seem to get these to work. I am due for another set of tyres and it's a tough choice. I'm keen on Toyos but my conservative side says Pirellis. It's for street driving, but don't care about wet performance, I tend to stay inside then. Looking for ideas on what tyre to try next?
Re11 and re11a(new version) are great tires, but get greasy fast in my experience. My current tire of choice is the MSS, with msc as a close second. I always found the n rated cups very predictable, personal experience of course.
I also run a 50-50 mix of 91 pump and 100 unleaded race fuel as well. Despite the race fuel being $9.50 per gallon, that's pretty cheap insurance compared to a damaged motor.......
The best bang for the buck track tire (price/perf.) is probably the NT-01. Not sure of the sizes for your car though.
It's been a while, and I didn't do a ton of track days on either tire but i think I slightly preferred the RE-11 to the SS. The RE-11 definitely gets greasy as it gets hot. Just cool them down a bit. The nice thing about them is that while they do get greasy, they don't get destroyed. Again, if memory is correct the SS don't like much more than 36 psi when hot.
Many prefer the BF Goodrich R-1 to the 888 but again, not sure about sizes. Just try different stuff - The nice thing is if you don't like them, you won't have to suffer long with them LOL.
