Esmotor 997tt es1000 build
Old 09-07-2013 | 06:10 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Originally Posted by Tiago
Can you tell us the distance on block between stock pistons and 4.1 pistons?
What is the max increase you can go with 4.1 pistons and modified crankshaft?
106mm pistons.
Old 09-07-2013 | 06:13 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Originally Posted by GTRNICK
106mm pistons.
106mm pistons with OEM crankshaft ??? Is it too big for sleeves ??
Old 09-07-2013 | 06:15 PM
GTRNICK's Avatar
http://www.fvd.de/de/en/Porsche-0/-/...__9.4%3A1.html
Old 09-07-2013 | 06:18 PM
ysfg35's Avatar
Yes , but i think it Requires diffrent Length of rods !! Not sure
Old 09-07-2013 | 06:28 PM
Tiago's Avatar
Tiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to behold
106mm pistons.
I was meaning the distance between cylinders walls with stock pistons and 4.1.
Old 09-07-2013 | 06:34 PM
GTRNICK's Avatar
I would have to confirm with Rhonda about the rods. I know you have to machine the water jackets. Also if you are doing all this work its no big deal to change the rods. I guess this a cheaper way of doing it. But the other way would be to change the crank!
Old 09-07-2013 | 06:46 PM
ysfg35's Avatar
Thats will be great , thanks for the info sir
Old 09-07-2013 | 06:49 PM
GTRNICK's Avatar
You are welcome bro anytime. I'm always happy to help you guys on here. Tuning is my passion brother.
Old 09-07-2013 | 08:19 PM
bimmer81's Avatar
bimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to behold
If 106mm pistons are available why does everyone opt for 102mm pistons. Is there an issue boosting a non stroked 4 liter engine?
Old 09-08-2013 | 06:44 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Guys,
3.6 liter oem dimensions are;
Piston 100mm
liner outside is 106mm, the thickness of the liner are 3mm each side
3.8 liter dimensions are; (3745cc)
piston 102mm
liner outside is 106mm, wall thickness 2mm each side
3.9 liter dimensions are; (3894cc)
piston 104mm liner outside is 106mm, wall thickness 1mm each side
4.1 liter dimensions are; (4045cc)
piston 106mm liner outside is 110mm, wall thickness 2mm each side
You need to modify the water housings and also the crankcase to fit these liners and much more compilications with this setup.
I have even one engine coming even with 107mm.
All these pistons can be installed with oem crank and oem rod dimensions.
All of 3,8 - 3,9 - 4,1 liter piston liners must be steel because of less wall thickness.
This is why most tuners go with 3,8. It has the most wall thickess and easy to fit.
All of these stuff seems easy to write, but there are so many details to calculate and consider if you want to build an efficient engine;
headgasket type, headstuds, compression ratio, piston dome design, rod/stroke ratio, balance, piston-rod weights, piston oiling, piston rings etc...
We are working on several different things to get 4.6 liter out of 6 cyl. boxer engine. I will give more info very soon if we succeed.
Cheers,
Emre
ESMOTOR
Home of the Worlds quickest Porsches
1/4 mile: 7,95 @ 190 mph
100-200km/h: 2.16 sec
200-300km/h: 3.43 sec
60-130mph: 2.52 sec
100-150mph: 2.19 sec
Email: emre@esmotor.com.tr
Web: http://www.esmotor.com.tr
Instagram: http://www.instagram.com/esmotor
Old 09-08-2013 | 09:45 AM
Tiago's Avatar
Originally Posted by Emre@Esmotor
Guys,
Cheers,
Emre
That is why your reputation is so high in this forum. Thanks.
So you don't play with crank and rods size to increase engine size. What is the reason? Higher costs?
Old 09-08-2013 | 09:59 AM
GTRNICK's Avatar
Guys,
Piston 100mm
piston 102mm
Cheers,
Emre
This is very good info Emre and 4.6ltr cannot wait to see.
You deserve a rep point!
Old 09-08-2013 | 10:37 AM
we also play with crank and rod size
we have 3 different crank and rod size
ESMOTOR
60-130mph: 2.52 sec
Old 09-09-2013 | 12:10 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Guys,
Piston 100mm
piston 102mm
Cheers,
Emre
+1 Great info. Thanks for sharing. That's why I stayed 3.8. Once you see everything totally apart, and then start putting in aftermarket/modified stuff, cams, pistons, studs, ring gaps, wrist pins, valve springs/lashes, you start praying that it is somehow all going to work. As Emre says, so many details and one little thing can screw you over. That why it's critical to seek out someone who really knows what they are doing. Nice work Emre. Can't wait to see the 4.6!
Old 09-09-2013 | 04:28 AM
ysfg35's Avatar
Great informations , thanks emre !!
So which setup is the best as performance , going with bigger bore (bigger pistons) or playing with crankshaft snd rods size ??? I know the 2nd option is more cost ,
