Esmotor 997tt es1000 build
Old 09-09-2013 | 07:10 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Originally Posted by ysfg35
Great informations , thanks emre !!
So which setup is the best as performance , going with bigger bore (bigger pistons) or playing with crankshaft snd rods size ??? I know the 2nd option is more cost ,
The 2nd option is the best option but like you said it will cost alot more money and bit alot more work!
That's why it is cheaper and easier to do the first option plus it still works regardless.
But if money was no object i would do the second all day long bro!
  #32
Old 09-09-2013 | 07:16 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Yes , you are right , playing with rods Length and crankshaft effect the performance/ TQ very well !
But it costs more !!
If anybody may answer ,
Option 1 , running big bore pistons 4.1L
Option 2 , running diffrent rods Length and diffrent
Crankshaft to reach 4.1L !!
both setups share all the same parts , turbo etc etc.. !
Which one better ?
How much HP will be diffrence ?
Which one remain daily drive ?
  #33
Old 09-09-2013 | 07:23 AM
GTRNICK's Avatar
Which one better ?
Again i would say option 2 will be better in all areas apart from your pocket.
Technically i have no experience with these kits so i cannot answer how much hp difference etc etc but i would assume a good gain throughout the revs and much more drivability.
Where Emre when you need him
  #34
Old 09-09-2013 | 08:04 AM
Tiago's Avatar
Tiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to behold
The big expense on option 2 is the crank mod. The rods it should be even cheaper than sleeves and pistons.
So how much can you gain from just crank and how much with just rods?
What will you do to obtain the 4.6cc?
  #35
Old 09-09-2013 | 10:29 AM
GTRNICK's Avatar
I'm sure 4.6 ltr will require alot of machining and the crank, rods, pistons and liner combination.
You are probably doing the same as 4.1ltr but achieving the extra 0.4ltr from the longer rods and a different crank.
I am sure someone will confirm this though as it would be nice to know.
  #36
Old 09-09-2013 | 12:58 PM
bimmer81's Avatar
bimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to behold
Emre, thanks for all the great info you are sharing. It seems that 4.1 liter and 3.8 liter share the same wall 2mm wall thickness. Would the machining weaken the case/water jackets for the 4.1 liter liners?
  #37
Old 11-10-2013 | 06:42 PM
Thenewguy's Avatar
Thenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of light
What transmission upgrades?
  #38
Old 11-10-2013 | 08:29 PM
cjv's Avatar
cjv
Moderator
I do not believe it is possible to obtain 4.6L with the current Porsche deck height and timing chain. At one time Koro made larger cases which could derive 5.0L, however to my knowledge they were not designed for turbo duty.
If anyone is interested in the formula to determine a motor's displacement, here it is. Post #2881.
https://www.6speedonline.com/forums/...ml#post2239168
  #39
Old 11-10-2013 | 09:03 PM
cjv's Avatar
cjv
Moderator
Which one better ?
Don't get your motor to out of square (Bore/Stroke). Option #1 without doing the math appears to be to much out of square. Torque will be the difference you notice with stroke increase. #3 This will be more a function of your turbo choice and tune.
Point of caution, with a 80.4 mm stroke an nice rod length to keep ideal piston/rod ratio's would be about 131 mm. To get to just under 130 mm's is very expensive. To get above this number requires heightening the deck height which requires a very special timing chain. Out of this world cost wise.
Again without doing the math ..... 80.4 stroke and 102 mm pistons would be very nice and a lot easier on your pocket book.
  #40
Old 11-10-2013 | 11:10 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
^^ good advice.
leevg
New Member Introductions
09-28-2015 06:59 PM
09-28-2015 03:19 PM
panas001
09-27-2015 03:51 PM
ek1
Bentley
09-27-2015 09:38 AM
Quick Reply: Esmotor 997tt es1000 build
