Independant Intercooler Test
Old 11-18-2013 | 04:01 AM
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
Originally Posted by GTRNICK
Obviously at your expense but at least you get to see if they really stack up against the rest!
I am already more than happy with mine, but thanks for your offer.
  #182
Old 11-18-2013 | 04:06 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
No problem Andreas you are welcome anytime.
  #183
Old 11-23-2013 | 11:21 AM
cjv's Avatar
cjv
Moderator
Tin minus Tout divided by Tin minus T ambient
Tin - Tout/Tin - Tambient = intercooler effiency
Tin equals Temperature at IC inlet
Tout equals Temperature at IC outlet
Tambient equals ambient temperature
Above is the equation we can use to quantify intercooler efficiency. Looking at the equation, you can clearly see that a higher temperature drop (Tin - Tout) is going to increase the calculated efficiency, but there’s more to the equation. The bottom of the equation (Tin – Tambient) takes ambient temperature into account because obviously if the air outside is colder, then the intercooler is going to transfer more heat to the cooling fluid, which increases the intercooler’s calculated efficiency. So this equation does a good job at leveling the playing field for varying ambient temperatures. That way, performing these tests in the dead of winter, or desert heat won't appreciably skew our results.
  #184
Old 11-23-2013 | 11:26 AM
GTRNICK's Avatar
Some interesting info you found there!
What we need is some more AM coolers to throw into this test to give us some more real data rather than just pure hype!!!!!
SpeedAddict
11-15-2021 06:19 PM
ysfg35
09-09-2011 09:49 PM
RUF QTR
05-22-2011 01:19 AM
MarkP
02-20-2011 10:52 PM
Abby997TT
09-13-2010 11:22 AM
