Sponsored by: Bears Transport
What is the stock turbo dyno and 60-130 record?
Old 12-29-2013, 09:06 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
You can see the Tip times are slightly better than the manual times I am guessing because the gears are slightly longer?
Old 12-29-2013, 10:11 AM
DNugget991GT3's Avatar
yup.
i'll beat a tiptronic's time though. its only right.
i was shifting at 6700, i should be shifting at no higher than 6k.
Old 12-29-2013, 03:58 PM
easy2speed's Avatar
easy2speed has a brilliant futureeasy2speed has a brilliant futureeasy2speed has a brilliant futureeasy2speed has a brilliant futureeasy2speed has a brilliant futureeasy2speed has a brilliant futureeasy2speed has a brilliant futureeasy2speed has a brilliant futureeasy2speed has a brilliant futureeasy2speed has a brilliant futureeasy2speed has a brilliant future
Originally Posted by Steve K ny
yup.
Why shift at 6k? Power fall off that bad?
Old 12-29-2013, 04:01 PM
yes.
shift at 6k, so that when i upshift, i am at my peak torque... VTG's run out of breath upstairs.
Old 12-29-2013, 08:47 PM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
yes.
shift at 4k, so that when i upshift, i am at my peak torque... VTG's run out of breath upstairs.
Wouldn't you want to shift higher than 4k, at whatever rpm level would net you LANDING at 4k in the new gear? If you shift at 4k, what is the rpm drop from 3rd to 4th?
Old 12-29-2013, 09:58 PM
i shift at 6k so that the car is at 4k (more like 42/4300) on the next gear, which is where i make power.
sorry that was a typo in my response to easy 2 speed. i meant to say yes, i shift at 6k because im not making more power.
Old 12-30-2013, 10:54 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Steve...
The abofe graph is for apr 95oct file...not for the 100oct race file...there is no graph at apr site for that...in reality manual997tt with apr and good exhaust revs that fast you simply cant miss rev limiter....there was a thread last year somewhere of a yellow 997tt that flashed it with apr race file and dynoed it...I ll try to find it...
Old 01-02-2014, 07:42 PM
easy2speed's Avatar
Just did a couple of runs in my stock car and realized you have to go into 5th to hit 130. That's going to kill the 60-130 on manual cars.
Old 01-02-2014, 08:59 PM
Chkmgnt59's Avatar
Chkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud of
Most tuned cars bump the rev limiter to 7k, which allows you to hit 130+ in 4th
Old 01-03-2014, 01:31 PM
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
tune , fvd exhaust, stock air filter. gt2 gears.
100 oct gas in the car.
will repeat. i promise.
What gears did you start and end the runs in?
Old 01-03-2014, 01:33 PM
Bingo!
Old 01-04-2014, 02:49 AM
Apr flash keeps rev limit at 6750 both for tip and manual cars...thus in a manual you need to shift to 5th to reach 130...however you can log a very fast 100 200km time....
Old 01-04-2014, 06:36 AM
nevertoo fast,
0 shift. just 4th gear. (remember i have different ratios 1-6, gt2)
60 is around 3.4k. so i brake boost, put some load on the motor and away we go.
Old 01-06-2014, 06:06 AM
nevertoo fast,
Yup, that's what I figured also, makes sense. The shift is what kills our 60-130 times on stock gearing and stock rev limiter. When I did the runs on the APR 100oct map, I got 7.5 60-130 and 5.9 100-200k. For the 100-200k I was able to do the run in 4th gear only.
BTW, how were you able to brake boost? I tried the brakes and handbrake, but the car would cut fuel after it detects throttle and brake input for more than 2 seconds. I tried turning off PSM and got the same result.
Old 01-06-2014, 07:17 AM
same here... it allows brakeboost for like 2 seconds and cuts off.. 2 seconds is better than nothing lol.
when i (finally) do my build, i'll have brake boost and a higher rev limit.
Quick Reply: What is the stock turbo dyno and 60-130 record?
