GT2 style plastic spoiler lip for 997TT?
#377
Thanks - ordered mine from 4caroption as well. It probably is the same guy/"company" as Xpert Tuning (and the others). Fingers crossed.
#378
That said the price difference between the stock lip and aero lip is just complete BS - pure margin for Porsche and I really wanted the aero spoiler look. My car is a daily so I'm realistic that this thing will wind up like the factory standard lip currently on the car that I installed back in Sept of last year - scratched to hell.
I've vacillated on whether I like the deviated black lower trim vs. body color, but being a daily is the main reason I'm not painting it body color (then requiring the consequential clear bra wrap). I've driven lowered cars (I mean slammed like a DTM car) my whole life and have never experienced an overhang like that of the 997.
On to the spoiler: It came without warping in its box. The ebay lip is definitely not "OEM" quality, but at $175 all in, what can one expect? The finish is rough - too rough to slap it on IMO.
My process to get it in presentable shape was the following:
1. sand with 200 grit electric sander to get the flashing and rough edges and get a scuff on it so the paint would adhere. wipe with tac cloth.
2. paint with SEM Bumper coat - color: flexible black ($15).
3. wet sand with 400 grit - wipe with tac cloth
4. spray
5. wet sand with 800 grit - wipe with tac cloth
6. finish coat
Sounds like quite a bit of work, but I've got a decent amount of experience painting and enjoy these types of projects. All in I spent about 1hr (not including drying time in between). I'm happy with the results - the finish is what I'd call a 2ft job. The only change I would make in doing it again is perhaps make the first coat a high fill primer or flexible primer to improve fill a few more of the imperfections.
I'll try to post some pics once I have it mounted. All in all I think it will do just fine for the 6 months it will likely last
#379
Good objective write up Uberm. I believe that the quality may have declined a bit since I got my two last year. I could have installed mine with no refinishing at all, and I believe that it would have been acceptable. I did, however have it finished in body color for aesthetics, but my car is not a daily driver and is not lowered.
#380
Received my front lip. Thought I would post up my experience. I'll start by saying I typically hate "knock off stuff" and am happy to pay a reasonable premium to get the real thing.
4. spray
6. finish coat
4. spray
6. finish coat
#381
Well, I consider myself pretty **** (my wife would say very). The finish I have now is miles away from where it was and has a "factory look". That said the real issue with these is the seam on the sides where it just wasn't assembled well and isn't flush. I think the for will be for so it really about the cosmetics. I wouldn't be scared - assess yours when you get it and go from there.
#382
I just installed mine. I simply sanded with 600 grit spending more time on the side seams making them near invisible, then flexidip or whatever its called 3 coats so now you cant see the seam at all. Let it dry overnight and installed this morning. Fit is tight and on the sides it sticks out just a mm or so but so did the stock one on one side so cant complain.
Its worth 3x the price if you ask me.
#383
TMI!! TMI!!
Mine came from Xpert Tuning this week. Box dimensions were 59 3/4 x 2 1/2 x 27. It was a slight bit narrower than the front lip, but it was not bent or otherwise damaged by being squeezed a little bit.
Address it came from;
15305 Stafford St.
City of Industry, CA 91744
I haven't taken it out of the plastic yet other than tear back a bit to check the finish. Seems like a surprisingly high quality part for $159 in the Porsche world, I'm going to have it painted and clear bra covered this week. I'll post pics when it's done.
15305 Stafford St.
#387
Sorry dude - . Maybe "particular" is a better word. Bottom line - mine was a turd out of the box compared to the stock $200 OEM porsche one I bought - now it looks closer to factory quality. It also had a blem on the left corner in addition to the ridges on the ends. The one from GMoney looks much better. YMMV.
#389
TMI!! TMI!!
15305 Stafford St.
15305 Stafford St.
Mine came from the same address. Shipment came in just fine.
