Video: world fastest Porsche 911 Tiptronic — Turbo DT1200R
#46
Guys, read plz again topic name!
Its fastest TIPTRONIC Porsche at any distance and quickest on 1/4 and 1 mile
Anyway its child games this year. Next season over REAL 1300whp instead current 1000whp .
#47
Now i have 900lbs and its holding perfect, not even one issue during last season.
2. My current shifting from 1 to 2 and 2 to 3 at around 7700, so i can shift at 8000rpm easy. Best of all i wish to shift at 9000 rpm but i have to change to solid lifters, stock max rpm is 8400 and i dont know about tip at such high rpm.
#48
1. Stronger? Maybe, but nobody except Emre, had never tested tip with more that 1000lbs of torque. I will test this season and write about results.
#49
I had my trans rebuild with similar specs, clutch packs, valve body, tcu tune, higher stall etc... It's back in the shop because it keeps going into Neutral at high torque levels. Did you experience any issues like that? Approx 750whp.
#50
Yes i was having such problems long time ago. That means that your clutch clearance is not proper. Also you should check in tcu tune limits of torque. Set it for at least 1300Nm
#51
Clutch clearance? Can you clarify? My trans box was modded by renntech and holding up at the 650/700whp level for a while; I wonder if im safe from this issue of the trans going into neutral at high torque as well as the tcu limits as I am revamping my fuel system and maxing out my alpha30s with the chance as my motors out. Any more info about that subject would be appreciated Megion
P.S rep points and amazing car.
#54
ESmotors tip porsche is surely faster and there might be other tip porsches that are faster. But as far as i know Megions time is the one to beat
#55
I think the issue is the NON-distinction between QUICKEST and FASTEST. Megion says he has the "FASTEST TIP PORSCHE" and then talks about his time. Well "fastest" is in regards to the trap speed. And ES Motors has gone faster right? "Quickest" is in regards to E/T. I'm not sure if he has the Quickest time, I think he might
#56
Sergey
We wanted to say congrats on another great accomplishment.
We are please to be a part of the build and look forward to seeing you push forward with that beautiful Porsche.
please let us know if you need anything
Kind Regards
Larry H.
Kind Regards
Larry H.
#57
So from what I understand doing a quick search there are some Lambos doing the mile in under 21 seconds and one Ford GT that did 280+ MPH. Is there any Porsche (or GTR or Vette or anything else for that matter) anywhere near these numbers. ???
#58
Esmotor team has much faster car's than this car you are already telling us esmotor has record of 60-130 100-150 100-200 what's left then to be faster then your's ?
#59
Quicker, not faster, is the issue here.
#60
Not even close
