Will upgraded intercoolers do anything for a stock 997.1 Turbo?
Yes as long as you put descent ones!
Just go for GT2 RS coolers unless you are planning to up the power alot!
https://www.6speedonline.com/forums/...oler-test.html
Unfortunately larger coolers will not cool the air better as there is more metal to conduct heat.
I have never fitted these and but from memory there is a thread somewhere explaining how to fit or at least some helpful info.
I think you can buy the ducts or just make some modifications to the originals.
They are identical in size, but there is thin metal lips on each side that either need to be rolled flat, or cut off. Bending the lip over is enough to fit.
oddjob142
08-19-2015 12:27 PM
