60-130
I need some help understanding how to perform 60-130 times. I do have a V-Box but not sure about the following...............
1. Do I start at exactly 60MPH accellerating through 130mph?
-OR-
2. Can I start at any speed below 60MPH accellerating through 130 using the momentum to obtain the best time?
3. Should I video record my run to make it "official"?
4. Can I do a 1/4 mile run allowing me to capture 60', 0-60, 0-100, 1/8 mile, 1/4 mile, 60-130, and 100-150?
Thank you!
-OR-
Thank you!
for 60-130 and 100-150 "record" times, it's better to do on the roads with the right slope
Unfortunately, I am in Florida, no slope to speak of here
.1 or .2 ? stick or pdk ? stock turbos ?
edit, just saw your other thread. youre making peak tq at 3200rpm ... 715ft lbs.
so start there.. 4th gear and hold on. try a 3rd gear pull too but shift early (if you post your dyno, we'de be able to give you a better idea as to when exactly you should shift and what gear you should be in.
but if youre making torque at 3200 i'de assume youre running out at 5000-5500 ish.
find a nice declining road, put her in 4th at 2800rpms, hold the brakes a little.. slam the gas and let the boost build up and see what you come up with, then do a 3rd gear pull but shift early and let her redline in 4th.
Two different cars............GT2 and Turbo S.
I am going to play with the shift points now that I understand the "rules". The GT2 peaks at 3750 and again at ~ 5100.
Don't be disappointed with times. With the rules being the way they are, there are lots of tricks to achieve great times.
3% slope with no max variation on a 60-130mph run, it's a game.
You can start on a incline, where the car doesn't have problems pulling hard at low speeds, and end up on a massive decline, where it usually starts to get slower. If in this distance the difference in height is less than 3%, it's a valid time.
With high torque cars, that have wheel spin problems, it's probably better to start on a decline and end up on a incline.
Best 68mm VTG time is 5.50s and there is a lot of controversy about that time (boost levels)
I wonder if people even noticed that, not too long ago, a 63,5mm VTG did 4.84s
Thank you!
FWIW, my best times have been slightly uphill. Have fun.
I was also wondering about the 1/4 mile, why are V-box times not acceptable if coupled with a video? I understand the reason of falsifying the data may be obvious such as simply running "X" car for "Y" cars time. However, not knowing how accurate a V-Box is I thought that may be the issue as deceipt could be applied to 60-130 times also. The diaper rule is a PITA
Understood..........
I have the full intention of running both cars in the 1/4. As the required diapers seem to be one size fit all I am a bit concern given our rear engine design. Has anyone purchased diapers which are in fact reasonably simple to apply and remove? If so, can you provide vendor and PN's? I would like to avoid the hastle of an exchange or credit.
Thanks!
Thanks!
Fadi
10-05-2015 12:14 AM
keithta
11-07-2008 02:15 AM
houstonT
05-15-2008 12:21 PM
