IPD Plenum Install, Dyno Numbers
Your car is setup pretty similar my car with the exception of the IPD. I was just wondering what kind of power and torque did you dyno'd. It is a little tough to read it off the graph you posted.
The car had been flashed by Euromotion in PR over 2 years ago for the previous owner so it is hard to say what has transpired since then, mods etc. I mentioned that the dyno looked low as I have attached one of the same file done with 91 octane on a stock car with a Mustang also. The top 2 are the Softronic runs and the lower was a different flash that was in the car at the time.
I wouldn't say the issue at the top or bottom end loss with the plenum installed is from the TQ limiters holding it back. Should this be the case then it should have reached the same level as it was run prior on the dyno. The gains in the middle are nice though. You can also see that higher HP and Tq was reached with the same file on this dyno .
Best Regards,
Scott
Best Regards,
Scott
Softronic - Porsche Performance Software Tuning
Faster than a speeding bullet.
Cayman | Boxster | 911 | Cayenne
Like us on Facebook for updates and promos
24HRS Daytona Winner programmed by Softronic!
Porsche Interseries programmed along with teamed owned Tudor and World Challenge cars in an exclusive with Softronic.
Porsche PCA racing binary check by Softronic for compliance.
So you that "limiter" can't be tune?
PenguiN
09-15-2015 11:44 AM
