Boost gauge on TTS, stock
I never really paid all that much attention to the TTS's boast gauge. I have mine set up in psi units.
I guess it's supposed to boost at 18, right?
Also, I noticed when you're at max throttle the boost pops up to 18-ish, but then goes down as the rpms build. Then, it's switches gears, boost peaks to 18-ish, and then it goes down as the rpms build, etc.
Is that normal?
Thanks!
Is that normal?
Thanks!
I do not think 15 is correct if you have it in Sport mode? I was assuming Sport Chrono, as not many people ordered without that option....and if so...why?
![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
997.2 is lower psi than 997.1
Over boost on the 997.2 TT is 14.5 psi (standard psi of tts).
DC
I've seen 15 psi in normal (non-sport) mode on my TT (non-S). In over-boost have actually seen 18 psi. I agree that I thought the boost was lower on a .2 and it's interesting that the bar indicator only goes to 14 (goes to 17 or 18 on a .1)
Hmm, I have a 2010 with Sport Chrono and a GIAC tune. I am only seeing 15psi while in sport PASM mode. Is this low? Or am I supposed to use the Sport Chrono feature?
Please advise.
Thanks,
Adam
Please advise.
Thanks,
Adam
On the bar gauge or the number indicator? With a tune the number indicator should definitely show more than 15psi.
I am using the number indicator which lists the PSI. Could the lower boost be a result of colder temps? It has not exceeded 60 degrees since I got the car and have been looking at the gauge.
Interesting! Do our gauges only read up to 15psi? What "log" are you referring to?
