Sponsored by: Bears Transport
HTA 3794R vs PT 6266 gen2
Old 07-04-2014, 05:54 PM
32krazy!'s Avatar
can i ask a silly question? so many folks talk about were and how fast the big turbos spool. i have 3071 tial turbos upgrading from my oem k24 turbos. i can hear them whistle at idle and it seems they pull almost immediately. with the power i have ( most i ever had) were should the power be coming in rpm wise? 2500 3500 4500 i never could get a straight answer or is it different for every car?
  #32
Old 07-04-2014, 06:32 PM
yumaverick's Avatar
yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !
If it's a stock block and e85 or ms109 I would guess 42-4500 rpms is where they will hit hard. My e911 kit would hit hard at 4500, which is a gt30 turbo with e85. If you are a built motor it would hit harder sooner as the torque can get brought in right away.
  #33
Old 07-04-2014, 08:21 PM
w00zy's Avatar
w00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to behold
I have the same turbos and I really can't answer that.
As soon I go full throttle, the turbos will start spooling, almost immediately, but peak boost depends on what gear and rpm I start pulling and the amount of boost I have setup.
  #34
Old 07-04-2014, 08:32 PM
w00zy's Avatar
I never felt the boost hitting hard at any rpm, it's very progressive, starts spooling early and fast. I want to believe it reaches peak boost, even at 1.65bar, sooner than 4500rpm's but never checked that... anyway, your turbo is slightly different than mine.
I only feel a hit of the boost if I brake boost and when I do, it will reach peak boost very fast... now that I think of it... probably not a good idea for my stock block
  #35
Old 07-09-2014, 01:20 PM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
would the lag be very bad racing from 60 on syvec ecu with rolling boost ?
  #36
Old 07-09-2014, 01:29 PM
yumaverick's Avatar
I rarely used my anti-lag because it's very hard on the turbos. I never needed it. I rather burn brakes then turbos. I'm not exactly sure how laggy my new set up will be. I'll def post lots of vids and vbox times as soon as I get the car back and I get used to it.
  #37
Old 07-09-2014, 01:30 PM
yumaverick's Avatar
I'm going to attempt a 60-130 with anti-lag a couple times though to see if I can do a pull without shifting.
  #38
Old 07-09-2014, 02:30 PM
Ok bro thanks . I hope to move to 997 platform soon and follow your steps
  #39
Old 07-09-2014, 03:01 PM
yumaverick's Avatar
Awesome!! Looking forward to it...I have a nice Switzer kit for sale cheap for you
  #40
Old 11-26-2014, 04:13 PM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
Do you mean "Power shifting = no lift" ???
  #41
Old 11-26-2014, 04:19 PM
yumaverick's Avatar
Nope I mean rev to 9,000rpms and do a one gear pull 60-130 in 3rd. Use the antilag in 3rd.
  #42
Old 11-27-2014, 12:57 AM
MegioN's Avatar
MegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to all
Tried 6266 gen2... They can make a lot of power but they are laggy as hell... **** it, i am swithching back to 3786hta
  #43
Old 11-27-2014, 12:59 AM
MegioN's Avatar
  #44
Old 11-27-2014, 02:27 PM
proTUNING Freaks's Avatar
proTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond repute
@MegioN, what is your current power goal? You're running a 3.8L correct? Is the car still AWD?
  #45
Old 11-28-2014, 04:43 AM
MegioN's Avatar
Yes AWD and 3.8L, power goal not to broke tip On 4th launch my tip was destroed
Quick Reply: HTA 3794R vs PT 6266 gen2
