Sponsored by: Bears Transport
Tiptronic problems, clunk - thump normal?
Old 02-08-2015, 05:18 PM
Slate997TT's Avatar
Slate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant future
My brother has a tiptronic 997tt 2009 with 35k miles, when I drove his car I noticed that when its hot and it goes from P to R there's a loud clunk - thump coming from the rear, also when going from R to D. I told him that mine didn't do that, so he took it to the dealer thinking it was the tranny and they told him it was normal at first, then when he confronted them and told them that my car didn't do that, they did further testing and blamed it on the tires Michelin PSS, same size as stock just different rims... His tires have around 7k miles.
I also notice the same clunk - thump is present when the car is hot and coming to a stop on 2nd gear, it doesn't do it all the time and only when is in regular mode, not in sport mode...
They change the oil on the tranny, and that didn't help, they reprogram the tranny and ecu and didn't help, the only thing missing is changing the tires but I don't think that will help him since everybody running non N rated tires will have the same problem.
Can somebody with a tip car check and see if it is normal? Also what do you guys think it could be? Tranny? Axle? Driveshaft. The car hasn't been abused or tracked...
Solution on post # 17
Old 02-08-2015, 07:22 PM
jessesick's Avatar
jessesick is infamous around these parts
Had this happen right after dealer put a new transmission in under some seal problem..... Blew the new trans within 150 miles
Old 02-09-2015, 04:57 AM
Slate997TT's Avatar
I don't really think is the transmission, I think it most be something else, when they changed the transmission oil, everything looked good in there, the tranny has no leaks and it shifts perfectly, no slippage, or loud clunk when in sports mode going up and down the gears
Old 02-09-2015, 05:12 AM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
Did they check the flex disk (guibos) on the drive shaft? That can make a bit of a clunk.
Old 02-09-2015, 07:36 AM
Slate997TT's Avatar
No vibration in the car, but I'll ask if they checked it out
Old 02-09-2015, 11:43 AM
SamboTT@ByDesign's Avatar
Trans mount most likely. They look ok when compressed sometimes but you take it off and you will see splits/cracks. Cheap fix hopefully.
Old 02-09-2015, 12:26 PM
MK23's Avatar
MK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud of
I have noticed in my tip that when I go from reverse to drive I have to wait a long-seeming few seconds before I push the gas. If I go in R to D quickly i will get a discernible thump and shaking until it engages and then lurches forward. I've taken it to the dealer before and they've said every things normal (I also had my transmission replaced at 32K miles for the dreaded "seal" issue). It's pretty annoying and even sometimes embarrassing when you're making a 3 point turn and have to wait a few seconds before pushing the gas as I'm sure the other drivers are thinking look at that a--hole Porsche driver just taking his time I don't know if this is the design of the tip but by comparison in my Rover, you can immediately change from R to D and take off.
Old 02-09-2015, 05:46 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
As mentioned...could be a tranny or even motor mount. Depending on how loud it is...it may actually just be normal...Especially if you have no other symptoms....
Good luck.
DC
Old 02-09-2015, 08:56 PM
THEWHEEL22's Avatar
THEWHEEL22 is a splendid one to beholdTHEWHEEL22 is a splendid one to beholdTHEWHEEL22 is a splendid one to beholdTHEWHEEL22 is a splendid one to beholdTHEWHEEL22 is a splendid one to beholdTHEWHEEL22 is a splendid one to beholdTHEWHEEL22 is a splendid one to behold
mine does the same thing, always has since I've owned it. Have had it in the shop for the major service and still does it. Maybe it's normal..
Old 02-10-2015, 10:41 AM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
I'll check mine when I back this W/e I think it does.
Old 02-10-2015, 02:46 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
I ve noticed that on a few 997tt tip cars...happens only when hot and with car completely stopped and brake pedal pressed when I switch from d to r and viceversa...note that clunk noise does not exist when cold and as temp of the car (not ambient) rises so does the noise...I dont think any mount would alter behaviour based on oil temp...finally if I switch from d to r with vehicle rolling forward (at 1ml speed) noise is not there....weird...
Old 05-09-2015, 07:08 PM
Slate997TT's Avatar
So we still having the same issue, we switch to ps2s like the dealer requested but we are having the same issue...
It only happens in regular mode NOT in sport mode which is really weird
Any help will be greatly appreciated
J
Old 05-09-2015, 07:28 PM
Alnoaimi's Avatar
Alnoaimi is infamous around these parts
I have a tip and it does the same clunk. I've been told that it's the mounts. Hopefully we get an answer to confirm that
Old 05-10-2015, 10:24 PM
PSTT07's Avatar
PSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nice
Interesting...I had a tip for almost six years and never heard a transmission clunk at anytime driving the car. This includes hot and cold. 21k miles on the car and owned in Phoenix, Houston and Seattle.
Old 05-11-2015, 07:04 AM
Slate997TT's Avatar
Weird thing is it only happens when in regular mode NOT in sport mode, that's the reason I think is not mount related, maybe software related???
Anyone?
Quick Reply: Tiptronic problems, clunk - thump normal?
