Throttle problem
Throttle problem
My car throws 3 CEL codes for throttle malfunctioning(P0121, P1637, P1086). Over 3000RPM does not make power.
Open flash tablet shows 30% throttle opening when I push gas pedal all the way. Car does not build boost eventhou there is no boost leak.
Is my throttle body motor/TPS bad? Is something corrupted with ECU?
Any suggestion would be appreciated/
Thank you.
Thank you.
What changed when it happened? Did it do it when you flashed the car? If so it sounds like a calibration issue. I would contact your tuner and have them check it out.
If you need anything please feel free to let me know.
Mitch.mckee@cobbtuning.Com
-mitch
-mitch
-mitch
-mitch
I see sudden jumps in throttle, sort of like noise spikes.
Could it be throttle motor? Should I reflash?
No problem good luck let us know how it goes!
Mitch
PORSCHE EXPERT GROUP - TIM BAILEY | JARED BRONSON | GRANT EPHROSS | ANDREW SCHWARZKOPF | HJ LEE
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE | CONTACT US
Mitch, I tried re flashing the original map and problem is still there. However more I drive seem like its getting little better. Maybe im imagining it.. not sure. Im trying to download the log but Im having issues with the SW.
Here is the CSV file I just drove 1-2-3, floored it but throttle reading would not go above 35%.... In 1 or 2 occasions, it would spike 100%. Weird, could traction control have anything to do with this?
Hello,
Try turning on the cruise control for 5 sec and turn it off.
This can help in some occasions.
ESMOTOR
Home of the Worlds quickest Porsches
1/4 mile: 7,95 @ 190 mph
100-200km/h: 2.16 sec
200-300km/h: 3.43 sec
60-130mph: 2.52 sec
100-150mph: 2.19 sec
Email: emre@esmotor.com.tr
Web: http://www.esmotor.com.tr
Instagram: http://www.instagram.com/esmotor
ESMOTOR
60-130mph: 2.52 sec
Throttle problem
Sorry to see your having problems. I am in now way a qualified tuner I've just been looking at my own logs a lot. I found it interesting you fuel trim bank one was 1.46 and your bank two was 0. I'm not sure what that means I know it's been put out that if it's over 1.25 across both banks your FPR needs attention. Not saying this is your problem.
It means the monitors are broken in the software. So they are incorrect.
Maybe try and take it to a dealer and see if they can do a throttle adaption.
-Mitch
-Mitch
What is throttle adaption? Is that something only dealer can do?
