997.2 No power to license plate lights
Hello,
I'm looking for some help. After taking my 2009 997.2 C4S Cabrio, to get it's annual state inspection, I found that the license plate lights were out.
I had previously changes these to LEDs, but my suspicion is that one of them has shorted something.
Here is what I know:
- Changing bulbs back to standard fuse style, and still no function.
- Verified that contacts are making good connection into license plate light receptacle/housing (black part).
- Verified each housing/receptacle has a good connection to the harness.
- removed rear bumper and verified that I am not getting any voltage to the harness located behind the bumper.
- Both tail lights appear to be working normally. (One thing to ask - does the vehicle have two fog lights or one ? Only driver side fog illuminates. Not sure if this was normal)
Here's what I'm missing: I don't have the fuse box layout document. I did go through EVERY fuse and none are blown.
I'm really at a loss for what to look for next. If I had shorted out a license plate light, how would I fix it ?
Thanks very much for any help !
Hello,
Hello,
On the license plate lights, how long did you wait after reverting to oem? For whatever reason, if the Led's caused an issue, it can take a bit for even the oems to start working again. Put them in and leave lights on for a bit...then check, and they will likely reset.
Good luck,
DC
Thanks for the feedback ! Time to stick the bumper back on, and I'll let the OEM bulbs stew for a while before checking...
Would never have guessed that a simple circuit like a license plate light that uses $1-2 in bulb, could be 'complexified' so much that it needs to run through the ECU. (and still the ECU doesn't tell you that the lights aren't working !)
therock88 - How long do you think it would take to reset ? I put everything back to normal (with traditional bulbs), waited ~10mins and there was no change. I was thinking of disconecting the battery to force a 'reset' ?
If you want to ensure everything is cleared in all modules...Disconnect both + and - cables and clamp them together for 5 minutes or so...This will discharge any memory stored in any of the components.
Hope that works. If not, sounds like you may have a more serious issue since you were not getting power to the rear harness at all?
Good luck...report back so I or others can continue to try and offer thoughts (if any additional).
DC
Ok.... so I drove around with lights on full for greater than 20mins.... still no light to the license plate. I connected the two battery cables together for much greater than 5 mins, no luck.
At this point I'm completely out of ideas... (but really apprechiate the help).
Is there another physical location where I can check the voltage etc, which could lead to some insight as to what's going on ? Otherwise, I'm thinking it's time to take it in and have it looked at....
Thanks!
Thanks!
I wanted to provide the final outcome for the use of others.
After some diagnostics it turns out that a diode blew in the rear lighting control module (under the drivers seat) which prevented power from being sent to the license plate lights.
westsiderkg
Cayenne 955/957
10-01-2015 12:10 PM
