If you have encountered P0021 or P0011 or any other cam advancement errors or issue
Old 11-11-2015 | 09:11 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Originally Posted by TAILWAG
Ok...here it is guys. Here are the parts for the actuator selenoids and also for the o ring - just in case. I guess sometimes the actuators will come with the o ring included and sometimes not...better order them just in case:
Let me know if you guys have any questions...seriously - bank 1 is about 5-10 minutes tops. Bank 2, if you are doing it by yourself, probably a good 15-20 minutes. With the help of somebody, probably 10-15 minutes.
Very helpful and good information! Thanks for posting! Rep point for you..
DC
Old 06-14-2016 | 09:27 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Thanks for posting this! Did you notice that the part number you posted is an updated part number? 99710530372 was the first revision....so hopefully there was some sort of defect and Porsche has since fixed.
I just did an oil change last week...probably 125 miles into just threw my first ever CEL. Hooked up durametric and P0021 and P1640 are front and center. CEL popped up while driving in slow stop and go traffic.
Question...is there something that can be logged/verified with a Cobb to confirm which one of the sensors/actuators is indeed at fault?
Old 06-16-2016 | 09:25 AM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
A regular scanner will tell you which bank is the problematic one.
Old 06-16-2016 | 10:16 PM
turboslut's Avatar
CEL popped up again. Scanned with Cobb AP and then with Durametric. Pulling two different codes. Cobb claims to have fixed the transposing issue....p2100 and p0021 are two very different problems and the cost factor between the two is absurd. How can I confirm the issue?
ID:	451263   Click image for larger version
Old 06-20-2016 | 04:28 PM
TAILWAG's Avatar
I would go w/the easy one first: replacing the faulty cam actuator selenoid on bank 2. It really is not that hard and you are only looking at a couple hundred dollars...basically, 2 oil changes worth. That could be the issue. If it is, then you are good to go. If it isn't, at least you know what to do next.
Old 06-20-2016 | 10:45 PM
turboslut's Avatar
Ordered the sensor and the o ring seal. Thanks for posting the part numbers
Old 07-05-2016 | 06:23 AM
turboslut's Avatar
Changed actuator yesterday.....reset CEL and nothing yet. The old one was tripping the CEL 30seconds after reset. Going to commute and see if anything pops up. I will also post some pointers on the actuator swap in a stock vehicle.
Old 07-05-2016 | 01:10 PM
TAILWAG's Avatar
Hopefully, that does it man.
Did you disconnect the battery or did you simply swap the actuator?
Sometimes when you disconnect the battery, the errors take a while to come back since the computer is still re-learning everything.
Fingers crossed for you!
Old 07-06-2016 | 10:21 AM
turboslut's Avatar
Thanks guys. I would not have been able to change this without you guys. Pretty straightforward once I figured easier to pull the harness plastic holder thing towards the back of the car to sneak my extension and socket behind it.
As Tailwag noted...screws can fall out of socket when trying to put them back in. I took some loose leaf paper...folded it once and placed it at the face of the socket. I then jammed the bolt into socket with the paper, thus creating a pressed fit (cut paper around socket)....no more lost bolt when trying to initially thread it into the hole.
Old 07-06-2016 | 10:23 AM
turboslut's Avatar
Cobb sucked here...not sure why the code readout was incorrect on the CEL
Old 07-06-2016 | 02:43 PM
turboslut's Avatar
I just swapped actuator (no battery disconnect), but I used Cobb to reset the CEL and I did notice that in the process the screen at one point says clearing ECM learning, so maybe it resets everything back to square one? 87 miles so far and still in the clear.
Old 10-14-2016 | 01:23 PM
vbb's Avatar
vbb
vbb is infamous around these partsvbb is infamous around these parts
Bumping this up as I have had the same thing happen. Driving along just fine, hit a bit of stop and go traffic and boom, CEL pops up out of nowhere. The car was driving fine and but for the CEL coming on I would not have known there was an issue. After a nervous drive home, praying that I wasn't doing any damage by driving the last 8 miles to my house, I got it in the garage and used my OBDII scan tool to find the P0021. A few minutes of searching and I found this thread.
I swung my my mechanic's shop (30yrs as a Porsche master tech, formally at a P dealership but running his own shop now) and he confirmed everything that I've read in this thread, specifically by TAILWAG. He said this is a pretty common problem and one he's seen a lot. He said sometimes it can just get stuck and once you clear the CEL it doesn't come back, so he suggested I try that first. If it does come back, he said the next step is to change the oil and swap the actuators to see if the problem switches from one bank to the other, at which point you replace the bad actuator and that usually is the culprit. Of course if that doesn't work, then it is time to pin the cams, which is labor intensive.
I bought the car used and with impeccable service records, but I've only driven it less than 1,000 miles so far. Though I got it from a P dealership, I talked to the previous owner as well, who told me he traded it in on a newer 911. I don't want to believe he's already tried all of these things and got out of the car before he had to do the expensive repair, so I'm hopeful it is just a fluke that this has happened to me now, and I'm extra hopeful that at most all I need is a new actuator and things will be fine. I'm out of warranty, so anything I need to do will come out of my pocket.
Old 10-14-2016 | 01:46 PM
turboslut's Avatar
The labor $ you will spend (if not doing it yourself) of swapping actuators and seeing if the bad actuator switches the code to the other bank is going to eat into money that you can just spend on getting a new actuator to begin with. I have begun to wonder if a failing actuator is ultimately the cause of the spun camshaft in the end (given that actuators do fail).
Old 10-14-2016 | 02:00 PM
saabin's Avatar
saabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond repute
vbb, BTDT, both with having the cam replaced on one side (thankfully under CPO) and then the other side (I put in a new actuator myself) and it hasn't been an issue since.
I bought a fidelity warranty to cover myself in case the other side ever needed a new cam.. Would've been 8K if I wasn't covered by CPO..
Old 10-14-2016 | 02:21 PM
vbb's Avatar
vbb
You're actually right... probably just as cost effective to buy a new actuator for the side that has failed and have that put on (with an oil change as well, because it couldn't hurt) rather than swapping and driving around waiting for the CEL to come back. In fact, now that I've cleared the code, if (and probably when) it pops back up, I'll just get the new acutator installed. That is the better plan. Thanks.
The mechanic seems to think this is the problem by the way... that the actuator just fails after time. I can live with that, though it is annoying nonetheless.
Yeah, there's an ocean of difference between replacing the actuators and having that fix the problem vs. having to do an entire cam job. I don't have a warranty and didn't get one simply because this is a "toy" that I plan to drive maybe 300 or 400 miles a month, max. That said, as with any used and fairly expensive car, you always hope to avoid the doomsday scenario where you get hit with a $5K+ repair bill. In fact, one of the motivating factors in selling my previous 997.2 non-turbo with PDK was that I didn't want to have a failed transmission and end up having to spend $14K on a total replacement. Figured the 997.1TT Mezger is old faithful, right?
Let's just say I'm hoping that the actuator is all I need.
