How does OEM 997.2 boost control work?
Old 02-21-2016 | 06:33 AM
changster's Avatar
changster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond repute
1) Mechanically, how does the factory boost control work? Given it's VTG turbos it doesn't seem to be an actuator driven system like "standard" type turbo systems in other platforms. As in, what is the actual physical thing that leaks off boost.
2) How dynamic is the software/ECU, and what is the interrelationship between boost control, ignition timing, throttle position, torque targets. Basically, what is the input and output. What inputs (sensors) is it monitoring, and what does it compare it to in the ECU table, and then what does it subsequently try to control (throttle, boost, timing).
3) How does Porsche estimate airflow given no MAF sensors, and is it very accurate/reliable data?
4) Cobb question - when you look at your datalog for boost (pre TB and manifold), is this in absolute pressure or boost pressure? Basically, do I need to subtract 1 bar?
agate911s
08-30-2019 06:22 AM
DerekShiekhi
Other British Cars
02-21-2016 09:50 AM
calrcm
01-29-2016 11:23 AM
PelicanParts.com
993 Turbo Vendor Classifieds
01-28-2016 11:59 AM
MadeInPorshe
01-26-2016 11:25 AM
Quick Reply: How does OEM 997.2 boost control work?
