997.1 known rattles...
Old 02-22-2016 | 02:08 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Hi guys....any known rattles in the cabin out there? I have a weird one when the bass hits sometimes. It almost sounds like a loose rear window, but I can't pinpoint it. Just looking to see if anyone has fixed any in their car in the past.
Old 02-22-2016 | 03:14 PM
TypeRx's Avatar
TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !
I had a rear window "creak" that was pretty annoying anytime the frame would flex (just about any bump), even just a tiny bit. I thought it was coming from somewhere on behind the interior rear panel (near the rear speaker) but when I had things off and coudn't find anything obvious, I went outside and started to push on the window at different points. I was able to replicate the noise so I simply took some foam weatherstripping (the cylindrical stuff) and wedged it against the glass (on the inside, under the rubber molding) and it fixed things.
PS -- others here have mentioned a "loose rear window" as a source of noise. The 911 rear windows are glued in and if you want to remove and reseat, it typically involves breakage of the glass. So, try what I mentioned. You don't even need to remove the rear interior panel -- just pull up the rubber weatherstripping and wedge the foam in there.
Old 02-23-2016 | 08:20 AM
Quadcammer's Avatar
Quadcammer is infamous around these parts
I believe the 997 side windows are attached with some nuts, and some people have had success tightening these.
I have a really annoying plastic clicking noise from the seat belt adjuster.
Old 02-23-2016 | 09:10 AM
cjcam930's Avatar
cjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond repute
I had one in the center console/shifter area. The big plastic console trim piece (shifter/between seats) was not screwed-in securely at all points. Fixed as a side bonus when I installed my shifter.
Old 02-23-2016 | 10:02 AM
turboslut's Avatar
I will check all these and revert back....thanks everyone.
Old 02-23-2016 | 05:49 PM
turboslut's Avatar
Checked the side windows and low and behold I can move them. I also found what seems to be dried up soap residue on the front corner edges of the side windows....on both sides!!! I don't understand how Porsche slacked with this? Is this a design flaw?
should I just tighten bolts or replace those inner rubber seals as well?
ID:	441078   Click image for larger version
Old 02-23-2016 | 10:57 PM
TypeRx's Avatar
You can pull the seals (just pull them up and follow around, paying attention to how you will reinstall) then use a watering can or low pressure hose on the outside of the glass to ensure there is no leaking. Like I mentioned above, you can the use a bit of thin foam backer rod (from lowes/Home Depot) to push the side glass outwards and keep things taut.
The "soap residue" issue you mention us weird, but surely you noticed this staining before?
Old 02-24-2016 | 07:49 AM
turboslut's Avatar
Yeah I am going to tackle this weekend. The soap residue has to be bubbles that seeped in and dried up. I use a foam cannon to wash the car and my soap is blue just like the residue. This is the first time I see this residue, but I am assuming it is because I just washed the car this past Sunday and used the foam gun for the first time. I am going to spray it this weekend and see if I can see the fresh bubbles come into the car real time.
I have also been searching the forums....a lot of people with 997 non turbos have had various problems with these rear quarter windows. One guy even had his glass detach from the mounting points and fall off the car.
I am just happy the bass in my new deep house music addiction helped me find this problem. Good mix below for those interested in rattle testing music
OCT
03-29-2016 11:04 AM
aerogt3
02-21-2016 03:54 AM
tiennd
Cayenne 955/957
02-20-2016 05:56 PM
acs370
02-16-2016 09:27 PM
PatrickBateman
02-16-2016 10:25 AM
Quick Reply: 997.1 known rattles...
