997tt bubly start up. Help!
Old 02-29-2016 | 08:35 AM
jaygotti's Avatar
jaygotti is infamous around these parts
So I didn't drive my 997 turbo for the whole winter season and went to go fire it up yesterday; the battery was completely dead ( not surprised). I plugged in the trickle charger I bought and let it charge for about 8 hours. When I went to go start the car it fired up but it wasn't running smooth like before, instead of a smooth buzzz it was like bubbly sound. When I get on it a little and let go the rpm would drop and then try to maintain idle. (No CEL). Does anyone know what it could be or experienced this before?
I took a video is there any way I can post it?
Old 02-29-2016 | 06:05 PM
cdk4219's Avatar
cdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to all
Possible bad battery, although there is a little learning that the PCM needs when the battery has been disconnected or is dead. If the battery is over 3 years old, and has gone flat, it may be time for a new one. German cars aren't fond of bad batteries and will do strange electrical things.
Old 02-29-2016 | 06:38 PM
vinnycg's Avatar
vinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of light
Agreed with ^. It is likely related to the battery and the car sitting for so long. How long did you drive the car for? Did you try to start it again ?
-Vin
Old 02-29-2016 | 07:39 PM
jaygotti's Avatar
Originally Posted by vinnycg
Agreed with ^. It is likely related to the battery and the car sitting for so long. How long did you drive the car for? Did you try to start it again ? -Vin
I didn't drive the car since November, I tried to jump start it with cables didn't do it, so plugged in the Porsche trickle charger and let it charge for 8 hours or so... And I didn't drive the car just warmed it up; I was told not to drive it. I have a video if you'd like I can send it some how. I was trying to attach it here but wouldn't let me .
Old 03-01-2016 | 01:03 AM
jaygotti's Avatar
Sent an email
Old 03-01-2016 | 02:04 AM
maverick997's Avatar
maverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to all
Did you add gas stabilizer before storage? If not your gas is shot...need to drain and refill with new gas.
Old 03-01-2016 | 09:16 AM
cdk4219's Avatar
Unless you are running on e85, the fuel more than likely is not degraded that much in 3 months. E85 will turn to crap real quick , but regular fuel will last quite a bit longer. I have a car that has the same fuel in it for 3 years, and starts and runs without problem. Not saying this cant happen, or that the fuel is better than it was 3 months ago, but it is a short time for fuel to degrade to the point of rough running.
Old 03-06-2016 | 03:16 PM
depending on your location all fuel now contains some % of ethanol. If the cars not running great most likely a contributing factor....fuel inj cleaner may help running that old fuel out....high performance cars on old gas, not the best recipe........I know for sure leaving fuel in your leaf blower for 3 months it will eat the soft rubbers in the fuel system...have the repair bill.
W.E. Cameron
03-07-2016 08:11 AM
zdr93523
16
03-03-2016 03:39 AM
technik
02-02-2016 12:59 PM
996_Carrera4S
02-02-2016 08:15 AM
sdanaher
02-01-2016 01:12 PM
Quick Reply: 997tt bubly start up. Help!
