Low coolant level 997 tt 2007
Hi every one , today morning while Im driving my 997 tt 2007 I got code ( low coolant level ) and it goes after 1 min later , after i parked i checked the coolant level its blow the minimum in maybe 1 cm , i checked the coolant above and under the car , seems every thing great theres no leaking , is this normal do I have just add coolant fluid from the dealer ship ( pink water )
Thank you
Thank you
You may have simply had a bit of air in the system that burped out.
I'd fill it to between min and max and see what happens.
If it continually keeps dropping, you will want to check the coolant fittings, water pump, and front radiators for leaks. If nothing there, then you'll need to have a closer look at all the hoses, lines, etc.
i will note, however, that some 7.1 cars seem to like to run close to the minimum line. If the level doesn't drop below that, you may just have one of those cars.
You may have simply had a bit of air in the system that burped out. I'd fill it to between min and max and see what happens. If it continually keeps dropping, you will want to check the coolant fittings, water pump, and front radiators for leaks. If nothing there, then you'll need to have a closer look at all the hoses, lines, etc. i will note, however, that some 7.1 cars seem to like to run close to the minimum line. If the level doesn't drop below that, you may just have one of those cars.
Thank you
How many liter i have to add ?
Hard for me to tell since I don't know what your level reads, but I'd plan on at least one liter.
obviously you'll want to combine coolant and distilled water in the percentage appropriate for your region.
alternately a hairline crack in your expansion tank. look for any white residue.. it'd be near or on top of your motor mounts and the tank itself might be yellowed. if so, simple replacement.
always fill with vw/audi/porsche "G13" pink coolant. you need to 50/50 it.
fais
03-09-2016 12:18 PM
