Help pls: clutch is much heavier prior to starting car in morning - leak AGAIN?
Thanks - another good thing to know.
Your accumulator is starting to fail. What happens first is it won't hold pressure over night. Next you will start to notice some subtle pulsation in the pedal when you press it in. This part is different from the slave. It's the black canister next to the slave on the transmission. Not Terribly expensive for another one plus install
This system is certainly failure prone. My car's slave cylinder was only recently changed so I am not replacing it for now, but next time I have this problem I likely will try the BBI slave. Thanks again - glad I asked here first; saved me a lot of time.
Glad you got it sorted. My engine was going to be out for the cam repair so I went ahead and cut the beast off at the pass, haha. Glad I did. It took a little time to get used to the firmness of the clutch pedal but I would do it again in a heartbeat.
