Installing injections
There is two bolts under the back of the car that are the motor mounts, You just loosen them till there almost all the way out. Do not go all the way out unless you have a jack under the motor. Remove airbox, ypipe, and everything on each side of the motor. There are 2 bolts on each side hold the rails down, unbolt pull injector and replace. The hard part is getting your hands in there, it is very very tight.
Ok perfect! When I did the install I pinched a oring on the injector and had a fuel like so it had to come back apart.
It is very difficult task and in order to have more access and do a clean job i removed the top oil line from the tank.
you can't do it properly only from the top you need some access from the side/bottom and you better off taking the rear bumper and ic.
I would suggest to do it with a lift or a pit.
All of the above and lowering the engine about 2" will take you 6-8hr to finish.
