Adapter caliper 350mm to 380mm
Hi ,
does anyone happen to have the adapter: 997 351 505 04 lying around? Dignity would like to build, I would already be enough.
That's the adapter to convert the 997 Tubo steel (350mm) to 997 Turbo ceramic (380mm).
Thanks in advance!
Thanks in advance!
if you drive 380mm PCCB on your 997 TT than you have the adapter for the caliper 225mm. Have you 350mm steel than you have no adapter and a caliper with 142mm.
If you want change the 380mm PCCB for steel disc than you van buy 991 Turbo discs with 380mm. The discs are plug and play!
you can drive the 991TT steel disc on a 997TT with PCCB at the front. At the rear you can choose the caliper with the caliper from the 991TT than you can drive the 380mm disc from the 991TT.
With this combination have you the 380mm at the front and rear in steel.
regards
regards
I believe the 997.2s already have 380mm brakes. This is for the 997.1s that have steel rotors. The PCCBs .1s are 380mm as well.
That's the GT cars...997.2 Turbo Steel is still 350mm
