P3008 CEL any help?
The one on the driver's side is a piece of cake. The one on the passenger's side, is a bit trickier. It is best to use a long extension and go through the space between the trunk opening and the hatch. Use a terry cloth to wrap the extension and prevent it from hitting/rubbing on the paint.
I'm seeing this same P3008 fault code on my 997.1 turbo. No CEL, just noticed it when reading errors with Cobb accessport. Car is stock apart from Cobb stage 1 tune and seems to run fine otherwise. Did replacing the camshaft position sensors resolve the code? Thanks!
