996 GT2 PCCB Rotors - 997 Turbo Install Advice
Looking for input on a PCCB install
I have a 2009 Turbo 997.1
i currently have the 350MM Red Steels as stock
Being that the 996 GT2 utilized 350mm i do not need caliper spacers for either axle.
can you tell me if the front 996 GT2 Hats will bolt up correctly onto my 997 Turbo Struts?
Do i need a spacer? do i need front 996 turbo hats? i do know of a set for sale.
i was cautios to buy a 997 set of PCCB rotors as they are 380MM and i believe the caliper fitment is far different or can you space out the caliper 20mm?
thanks
thanks
Thanks for the guidance
I was able to locate a set of 350MM 996 GT2 gen 1 PCCB rotors
Thankfully I can reuse my calipers
I have a 2009 997.1 turbo
Very curious to see if the fronts will bolt right up,
I need to just give it a shot, I did learn that different models have different hat offsets
Does anyone know If these 996 gt2 fronts will bolt right up?
I can source a set of 996 turbo front hats, shall I go ahead and just do that?
What are the spec differences between the turbo and gt2 hats?
Originally Posted by Scuderia V
[/size]
They will not
They will not
If I purchase 996 turbo hats and install them onto the front PCCB rotors will they bolt on?
I am trying to determine the variation to make this all work
Thank you
vshugo996
09-12-2010 07:58 AM
