Suggestions for V1-concealed display unit
I can etch the glass in almost any pattern but cannot really change the layout of the lights, or not without a lot of work. The LEDs are all surface mount and very fiddly. However within the current design I can vary the size and so on, I'll see if I can do a mock-up that looks more compass-like.
This is a rough mock-up to try and describe what I mean, I can change the shape of the indicators and the markings but cannot move them, here for example I have resized the arrows to look more compass like and altered text (I didn't put a lot of thought in to it!!) to diguide the other elements, they are still essentially in the same places though.
Any bright ideas for markings would be most welcome!
Chris.
Chris.
What about not etching/labeling the "temp"/bogey count box, dots for band type and no label for the signal strength bar/"boost" (maybe just slightly progressing in size and only 5 or 6 of them. Instead of labeling the "Compass" just go with simple, clear arrows.
. . o O 0 v
Not as fancy as yours but should get the idea across. The basic info,discrete look. Simple direction and signal strength info.
Other option is to figure out a spot on/near the guage cluster to mount a modified concealed display.
Originally Posted by Atlas
oh well, keeps changing my arrows when I enter it!!!??? Better at concepts than computers, sorry
I like the first one in post# 20. #21 is not bad either but I never really cared about what type of radar it was, I always slowed no matter what. The laser is a different story, but that is what the Lidatek LE-30 is for. The bogey count is useful but takes up too much room in the display (IMHO). For me, I just want the most discrete display, short of the cost of a concealed unit like RX75 or SR7plus. I like to move the V1 to whichever car I drive.
Bottom line is I could do any of them so it's more of a personal choice than anything. I've also added logos for some people to the center of the mirror then painted it form behind so it shows through in solid color.
Chris.
Chris.
Great idea with a small mod
Originally Posted by BD 997
I'd say on top of the steering column....
Before making my mirror I had the remode display stuck under the dash down by my right knee, I had a clear view of it down through the wheel and it was nicely shaded too. The downside is the mute button is a bit of a pain to get to. I've also wondered about mounting it in the batwing although I don't think there is one in the 997 is there?
then it will not be concealed.... people driving behind you will be able to see it.
Originally Posted by LSM
You would still have to mount the V1 somewhere visable although the lights wouldn't light up on the unit but rather on the mirror...It still has to detect radar from the unit
Chris.
Originally Posted by ukchris
I originally had mine mounted slightly to the right of the rear view mirror. I couldn't see it from a driving position but the rear facing sensor was still clear. One thing to note, in the display area on the V1 itself there is a circle between the "Ka" text and the numeric readout. THAT is the rear facing laser detector. I know what folk say, once the laser alert sounds it's too late anyway but thought it worth pointing out, I had assumed all of the sensors were in the blank part to the right.
Chris.
Chris.
Unless....someone can take out the guts of the V1, place them in the headliner, and have the arrows displayed remotely...Possible??
There are details here http://www.540i6.com/v1.html I have no affiliation or knowledge of how well it worked, I prefer the clear line of sight approach.
Chris.
