wheels and spacers
wheels and spacers
I am planning to change the OEM front 8.5x19 +56 rear 11x19 +51 to these BBS wheels http://www.bbs-japan.co.jp/pro/pro_lmr.html size front 8.5x19 +55 rear 11x19 +63. However, to compensate the offsets. I will need to add 5mm spacers in front and 17mms spacers in the rear. so the front +51 rear +46. By changing the offsets, is it going to change the handling? (understeering/ oversteering)? What are the pros/ cons?
i did some hw for those LM-R. they're perfect for narrowbody C2S etc. the spacers u are going to add will not affect the handling much. even factory runs 5 & 17mm spacers for some wheel set up. u'll be fine.
The only issue with the LM-R will be availibility. BBS is being pretty tight-lipped on when they will be ready for sale. I can't get anyone to even say they will be ready in 2007.
Hopefully soon because this is going to be a GREAT wheel.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
I have 18mm forged spacers from boothedesign.com and they work fine with my GT3 wheels. Just have to make sure that you check the nuts every now and then. Also use the factory bolts too since they have the proper chamfer angle. I used aftermarket bolts and they kept coming loose.
Can you explain need for spacers w GT3s
Originally Posted by johnww
I need a 101-lesson in spacers. Why are they needed with GT3 wheels??. These should fit the turbo?? Are you saying because the 4-wheel drive needs the wheels out further and the GT3s don't do that enough?? Thinking of getting HRE 21s....do these need spacers too?
The GT3 RS is based on the widebody and as such their wheels do not need spacers. If you were to use those wheels on the turbo then you wouldn't need spacers.
PelicanParts.com
930 Turbo Vendor Classifieds
08-18-2015 04:01 PM
PelicanParts.com
08-18-2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
