Void Warranty??
There are different types of redline (I think six gradations), basically "hitting the limiter" type and "missed shift" type. The former don't void your warranty (that's why the limiter is there)-- but I wonder if they would hassle you nonetheless if done during breakin.
The latter can be used against you to deny warranty service.
The DME stores info on when you redline and how long you spend > redline, so they would know whether it happened during break-in.
My personal view is that rev-limiter events prob can't cause major problems, even during break-in, but I worry a bit about a random and unrelated problem "blamed" on hard driving during break-in and resulting in a denied claim.
I would guess that the rev limit has a good safety margin, not like the engine will blow at 100 rpm past the limit. There is nothing to keep you from over reving with a very early downshift though. That's where the real damage can happen and that is sure to be recorded.
Dosn't answer your question though.
OT but a lot of stuff is recorded in a lot of places. A friend with a BMW suv had it catch on fire while he was driving it. He got out as the engine started to burn up, and took the key with him. He told me BMW voided his warranty because he was driving the thing for a very long time with an overheat alarm flashing and the dealer got that information from the chip in the key!
Originally Posted by jimdarcy
Is it the time spent in the red zone of the tac or whether the limiter has been tripped? Can Porsche deny service, warranty or otherwise, if they detect any "events"?
thanks
Jim
thanks
Jim
However, I'd suggest that you re-read your warranty documents twice before.."Porsche Cars N.A. will repair or replace with a new part distributed by Porsche Cars N.A., at its sole option, any factory-installed part that is faulty in material or workmanship under normal use. (Normal vehicle use is described in the Porsche Approved Limited Warranty Booklet.)"
It seems as though the dealer is snowballing you....As i have mentioned above, i suggest you ask for everything in writing...that way you can ensure there are no loose ends.
For additional info please go to this link: [url="http://www.sunsetimports.com/porschepowarr.php"]
Cheers and GL,
Kamil
One more thing....I looked into it a little more and it seems that if the dealer can show you that damage has occurred due to over-reving..then you're out of luck...Here's the catch: I think that when the sales associate says, "read your manual and driver's guide before use"....he automatically takes care of all liability issues...smart... Further, remember that Porsche can look into the cars system and retrieve all the information that is required. Lastly, you must remember that it is not the engines fault that you over-reved...it's the drivers fault. Hence, warranties do not cover driver error.
Kamil
Originally Posted by kamil
I'm almost sure that there are laws which prevent manufacturers from, well, cheating consumers...You should contact the dealer and ask for all of this in writing.
However, i'd suggeest that you re-read your warranty documents twice before.."Porsche Cars N.A. will repair or replace with a new part distributed by Porsche Cars N.A., at its sole option, any factory-installed part that is faulty in material or workmanship under normal use. (Normal vehicle use is described in the Porsche Approved Limited Warranty Booklet.)"
For additional info please go to this link: http://www.sunsetimports.com/porschepowarr.php
Cheers and GL,
Kamil
Cheers and GL,
Kamil
Jim
used?
Lets say you purchased a car with 7000 miles on it and the previous owner had it in the red all the time!! How can a buyer protect themselves from that?
A full diagnostic inspection will be required every time you purchase a vehicle........!!!! No more private sales.
[quote=kamil]I'm almost sure that there are laws which prevent manufacturers from, well, cheating consumers...You should contact the dealer and ask for all of this in writing.
Cheers and GL,
Kamil
This business of driver error.....if an automatic tranny, there is an electronic block if a downshift is made at too high a road speed (mechanical overrev conditions). This could also be the case with standard transmissions, Porsche could provide a similar shift block too. However, Porsche (&BMW) makesthe shift so easy to do into second at speeds over 70, especially in a panic mode to avoid an accident,that an overrev can happen easily. At least with US-HP cars, the transmission will grind. I notice now the SMG transmissions have electronic blocks to avoid overrevs. Its weird, this driver error principle is crap, a driver can run into a tree, clearly driver error, totally wipe out his car and insurance pays, but god-forbid if you move that hand that 1/8 inch too much moving from 5th to 4th and hit 2nd to avoid killing someone.......for this error shown on the car's computer, Porsche will not honor the warranty nor will insurance cover the "driver error" damage. If an overrev happens, best to run the car into a lake, then all damages including the bent engine valves will be paid for. This auto insurance world is stange indeed.
Cheers and GL,
Kamil
I am surprised warranty claims are such an issue, given that a Porsche dealer sees his customer once in two years for a service which is not overly expensive, that the would argue about warranty work, Its all money to the dealer in claiming it from HQ?
Unless the hoops they have to jump through to claim warranty costs are to hard to overcome? Comments?
I know LandRover regularily put things through and just see it as workshop time therfore money to them?
jaehoppa
10-22-2015 09:17 PM
Vrrooom
09-15-2015 02:03 PM
