New fabspeed air intake, looks killer !
#32
Dyno verified by Phoenix Performance, winners of multiple SCCA T1 championships and factory technology and racing partners for GM (General Motors) and Subaru USA. Phoenix facility features body shop, multiple race and engine shops, dyno room, etc.
We have pointed out 3 separate RPM's to show how significant the power gains were.
2700 RPM
+26.13 TQ
+13.5 HP
4200 RPM
+19.87 TQ
+15.96 HP
6100 RPM
+25.01 TQ
+28.92 HP
Your 997TT will make significant additional power over the entire rpm range.
All numbers are horsepower and torque to all 4 wheels via the 4 wheel dynojet. Multiply these numbers by 20% to get corrected power at the crankshaft.
We are taking orders
$850 plus shipping
#33
The dyno graph perfectly illustrates why peak #s are not as relevant as area under the curve - while the intake appears to "fill in the gaps" on a couple of points compared to the stock intake (resonance related?) the gains only cover a few hundred RPM. Thus, on the dragstrip or road course the power gains will only appear as large as their effect on the average power across the useable powerband.
If we consider the operating range of the 997TT engine 3000 - 6800 RPM (which is generous) we see that the intake picks up ~16 HP from 4200-4400 RPM, and loses roughly the same amount of HP at 4800-5100 RPM. The graph becomes hard to read at that point because of writing, but it clearly shows a gain of ~20HP (avg) from 6000 - 6400 RPM.
So - average HP across the powerband of [3000 - 6800] goes from 340 HP (stock w/mufflers) to 342 HP (above w/intake) -- about a 0.7% gain. This is equivalent to removing 25 lbs from the vehicle.
#34
I am sorry but what I am seeing in the 2 lines can be explained just by the scaling the resolution of the dyno. The 2 plots overlap almost exactly save for a couple spots of variation which last less than 200 rpms. Measuring the total area under the curve the results are going to be within 0.1% of each other. Run a stock car 3 times on the same dyno same day you are going to see that much variation as it is.
#35
Looks to me like it makes power pretty much across the entire RPM band. There are a couple of little dips, but at least it's not losing power.
Stephen and the other tuning gurus what do you guys think?
#36
If the stock airfilter was a source of restriction, there should be an increasingly diverging pattern at the far right of the dyno when airflow is at the maximum. I don't see that at all.
#39
I will have a unit very soon. Hang on with the judgement until we have some data. The Vflow made a real 15HP to all four wheels so that doesn't rule out all the claims. I will have some data by the end of the week. I wouldn't had guessed we could have done what we have with stock VGTs.
#40
Originally Posted by jiaim
Found on the fabspeed website, maybe some didn't seen yet, sorry if it's a repost.
Hope to see some numbers ,I think it looks nasty, love it !
It would look even better with some bmc double cone filters
#41
This is Joe @ Fabspeed Motorsports. I designed and tested many versions of the Maxflo CUP high performance air intake system. The filters that I used have velocity stacks inside and these made more power than the BMC F1 GT3 CUP filters that someone photoshopped above.
The OEM Porsche 997TT twin cold air ducts DUMP cold air directly onto the Fabspeed twin filters and the rear engine fan blows cold air into the engine bay. I have tested my car for over 2500 miles from 88degrees down to +6 degrees frigid cold. No CEL lights and much more power in the seat of the pants and as verified on the dyno all across the curve from low end to max rpm.
The factory Porsche 997TT airbox outlets are smaller than Fabspeeds and the right side passenger OEM duct from the factory Porsche 997TT airbox is squashed/crushed to clear the A/C compressors lines. Porsche engineering therefore made each side ducts compromised for the power output they engineered. I went to much tighter radius C.N.C mandrel bent tubing which greatly outflows the stock airbox under all conditions.
IF anyone wants to come by the drive my car let me know.
Have a great day
Joe Fabiani
Have a great day
Joe Fabiani
#42
Joe, what do you say about the question of water dripping on the intake filters in the rain and effecting the MAF, and, or CEL's? I have personally seen that be a problem on similar kits with one less filter and some sort of water shielding.
#43
Originally Posted by 993RSClubsport
[...] much more power in the seat of the pants and as verified on the dyno all across the curve from low end to max rpm.
No offense, but how can you possibly make that claim? Look at the dyno chart which you produced as evidence -- there is NO additional power on almost the entire curve. As eclou mentioned, I've seen more variation on back-to-back dyno passes than there is on the curve you posted.
Frankly I'm not convinced the stock intake is a significant source of restriction at near-stock power levels. Todd @ Protomotive has seen 561 AWHP through the stock airbox & tubes, and my car still uses a bone stock intake and is making a durn sight more than 430 AWHP.
#45
Originally Posted by treynor
Joe,
