New GT3RS wheels installed!
Old 02-27-2007 | 03:48 AM
atomic80's Avatar
Originally Posted by mr2guysingh
Nice car! Where do you live in Bellvue? I'm on Lakemont...
I'm about 2 miles North of Bellevue Square.
  #32
Old 02-27-2007 | 09:52 AM
jhbrennan's Avatar
Originally Posted by atomic80
I have a set of Porsche OEM black lug nuts as I said earlier. I got a set of black wheel studs to use up front. The dealership accidentally ordered a set of silver wheel studs which were a bit too long. That's why they used the stock bolts temporarily until the correct studs are sent to me. That's why you see the silver bolts in the close up shots. I should have the black ones on by Tuesday/Wednesday.
Thanks - what did you have to do so that you could use lug nuts instead of lug bolts?
  #33
Old 02-27-2007 | 10:01 AM
atomic80's Avatar
Read my post carefully, please...I used wheel studs. You put these in the axle then use lug nuts with them.
  #34
Old 02-27-2007 | 02:49 PM
jhbrennan's Avatar
Thanks - much clearer to me now. Another question - where did you get the stud kit? Thanks again.
  #35
Old 02-27-2007 | 03:01 PM
iLLM3's Avatar
DAMN what a nice rump LOL, loving it
  #36
Old 02-27-2007 | 07:18 PM
atomic80's Avatar
My dealership ordered them from the RUF auto center in Texas.
  #37
Old 02-27-2007 | 07:53 PM
unique's Avatar
unique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud of
atomic bro.... u are doing a great job with ur car.... the cargraphic is sick and the wheels are even sicker.... keep it up....
  #38
Old 02-27-2007 | 10:42 PM
WyattH's Avatar
WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !
Yahhh boyyy!
  #39
Old 03-02-2007 | 03:35 PM
c40carbon's Avatar
c40carbon is infamous around these parts
I initially had put on a set of wheels from the GT3. The front wheels were the same as the stock Turbo wheels but the rears had an offset of 68mm which were quite a bit more than the stock Turbo 51mm offset so I had to use 18mm spacers to compensate. I wasn't too happy with the initial look and the car didn't feel as "tight" around the corners as I'd have liked.
I came across a set of wheels from the GT3 RS which is a widebody just like the Turbo with wheels designed accordingly. These wheels had an offset of 51mm just as the Turbo wheels do so no more spacers would be needed. The car once feels as tight around the corners as when I first took delivery not to mention how good it looks!
No more spacers
Deep concave dish look
Vantage shot with the new wheels
The view that most folks see when I'm around
Very happy with the latest mods! And no, I'm not planning to swap springs. I scrape the front end already as it is even when driving at an angle.
I am not familiar with how offset works. But 997tt front stock wheel's offset is ET56 and GT3 front wheel's offset (one you have installed) is ET53. There is 3mm difference. Doesn't it require 3mm spacer (if there is a such kind ?) ??? I would appreciate your advice.
  #40
Old 03-02-2007 | 03:41 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
it just means the wheels will stick out 3mm more.. which is neglible. spacer would do the opposite - push it out further.
  #41
Old 03-02-2007 | 03:43 PM
20C4S's Avatar
u want a set of Techart tips?
  #42
Old 03-02-2007 | 03:48 PM
jhbrennan's Avatar
Absolutley correct - here's 3mm _
  #43
Old 03-02-2007 | 07:01 PM
atomic80's Avatar
Here's some interesting information:
Model Track
Front Rear (mm)
GT3 1486 1511
Turbo 1490 1548
GT3 RS 1497 1558
I'm pretty sure that it's not just the wheels that could attribute to the wider stance between the Turbo and the GT3 RS.
  #44
Old 03-02-2007 | 09:21 PM
cooperlee's Avatar
cooperlee is infamous around these parts
did you use the same OEM tires on these wider RS rear wheels of 19x12?
  #45
Old 03-02-2007 | 09:28 PM
ss360's Avatar
ss360 is infamous around these parts
they really are nice wheels
