Anyone have a list of ECU trouble codes?
Old 05-21-2007 | 03:58 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
Looking for a reference list
Old 05-21-2007 | 07:43 PM
raygr's Avatar
raygr is infamous around these parts
You might find what you need here: http://www.obd-codes.com/
Old 05-21-2007 | 08:33 PM
eclou's Avatar
Well,
I found out what I needed to know. P1095 and P1096 popped up on my car after a track day today. Basically a MAF error code. Rummaged around the car and found out I had managed to pop-off the passenger side boost tube to the intercooler inlet tank. Popped it back on, cleared the codes and everything is cool again.
Old 05-23-2007 | 01:12 PM
chrisn's Avatar
chrisn is a name known to allchrisn is a name known to allchrisn is a name known to allchrisn is a name known to allchrisn is a name known to allchrisn is a name known to all
eclou:
Did you get a check engine light? notice anything else about the car (low power)?
Thanks!
Old 05-23-2007 | 01:16 PM
eclou's Avatar
when the boost hose was off the car would not hold an idle nor would it rev past 3k, and the CE light came on almost immediately
Old 05-23-2007 | 02:49 PM
raygr's Avatar
That makes sense. The engine is sucking un-metered air (so it probably thinks the MAF is wacked). Funny, but this is the 3rd such incident I've seen in about 2 weeks (on different cars).
Old 05-29-2007 | 02:15 AM
Aisxos's Avatar
Aisxos is a jewel in the roughAisxos is a jewel in the roughAisxos is a jewel in the rough
Well,
With what pc program do you read the Ecu and reset the errors?!
I am thinking of buying from www.durametric.com Is there anything else that I have to consider?!
Old 05-29-2007 | 06:54 AM
eclou's Avatar
I bought an Actron 9180 scantool off eBay for about $100. It works on all my cars. Durametric is not ready for the TT yet (from their info)
Old 05-29-2007 | 07:17 AM
jhbrennan's Avatar
What type of connector do you use and where is it located on the car? Thanks.
Old 05-29-2007 | 11:32 AM
eclou's Avatar
All 1996+ cars use a standard OBD II port. In the TT it is located just below the steering column over the left footwell. You need to buy a scan tool that is compatible with the newer "CAN" systems.
Rguy
04-12-2020 11:11 PM
DLF
Cayenne Turbo
10-24-2015 11:27 AM
AuZZie
09-02-2015 04:26 PM
AdPock
Ferrari
09-01-2015 10:13 PM
Quick Reply: Anyone have a list of ECU trouble codes?
