New ECU EVO EVT S2 580 getting PSM code wont start
Can some one help
I just installed my new ECU programed with EVO EVT S2 580
the car will not start and I get a PSM Failure code.. Can someone help?
Badbruno
Badbruno
Try disconnecting the battery, check ecu fitment and install, reconnect battery and test. I got a pasm/psm failure when i disconnected the battery, it cleared up after a couple minutes of driving.
Ok I had the same problem...
If this is a spare Ecu (2nd) you have a progblem with the sasi number (Vin). They have programmed something wrong...
Now on the other hand if it is your old Ecu I dont know what it is wrong..
Now with the error codes you have to see what it says.. When this had happened to me it had error codes P2188 P2190 which is system too rich at idle.. From then I havent found yet what is wrong in order to erase these codes..
Yes I did disconnect the battery.. I plugged the orginal ECU in and the car starts now but PSM Failure is comming up..I'll try and drive to see if it clears up..
Thanks everyone!!
Badbruno
Thanks everyone!!
Badbruno
Reading the forum I have seen that you had p2188 p2190 in your car. Last week I had p2190 after refueling. It was clear and yesterday again I had p2190.
Did you finally discovered what was the problem in your car?
I will appreciate your help.
With respect,
Antonio
Was this a new ECU that we modified, or was this ECU running in your car before it was sent in for the upgrade?
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Before sending it back to Evo take your car and spare ECU (the one you want programmed) to the dealer and have them code the new ECU. THEN send it to Evo and when you get it back you'll be good to go.
Been there and ALMOST did that.
