Taking a survey regarding the stock suspension on the 997 TT
#31
I just spoke to H&R about their just released coilovers for the 997 Turbo. They will not make a PASM enabled coilover because they feel that with the coilover system there is not point since it is already damper/rebound set from H&R - so the PASM is redundant.
It is only height adjustable.
The question I pose is this( sorry if I sound like a noob ):
PASM "stiffens" the settings of the shock setup correct? So if you get a damper/rebound capable coilover why would you need PASM? Since you are dialing in the "adjustments" then why the need to change it with PASM?
Just a newbie posing this question for those who are guru's or more of an expert than I.
Thank you.
Thank you.
#32
Just got done with a DE at Pocono, I experienced no high speed issues lap after lap at up to 148 mph in the red group. My car is stone cold stock with the factory alignment. Very different than the 996TT/4s awd setup, better, more rw biased, just takes some getting used to that's all.
#33
#34
Only slightly 'floaty' with the non sport mode with a high speed righthander, otherwise fine, esp in sport mode. The only limiting factor, limiting my entry speed into corners, were the street tires. In the straights, it flat hauled ***, no instability whatsoever. If I had cups and a more aggressive alignment nobody would have been near me in the straights or twisties. I checked my alignment before I went, left it at the stock specs(-.4 fr cbr/0 rear toe). By the last session in the red/black group I was running with a bunch of race cars practicing for the enduro, trust me to keep up I had to push it very hard....it held it's own against a lot of pure badass track beasts. If I told you the cars that I was passing, you wouldn't believe me.
The awd system is very rear biased and takes some getting used to, much superior to my 996c4s, awd/x73 in every respect.
I'll try and post a nice video in a couple of days, gotta sort out my new camera.
C
C
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
08-18-2015 03:41 PM
PelicanParts.com
08-18-2015 03:39 PM
