Trying to decide which springs to get
Old 07-17-2007 | 10:57 PM
terrence's Avatar
terrence is a jewel in the roughterrence is a jewel in the roughterrence is a jewel in the rough
Choosing between Champion and Techart. I hear Champions are made by H&R. Looking for the best possible ride while having improved appearance compared to stock.
Thanks for your opinions.
Old 07-18-2007 | 02:31 AM
whomikem's Avatar
whomikem is infamous around these parts
Facing the same dilemma. How much does each set lower the car?
Old 07-18-2007 | 07:51 AM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
I am in the same boat. The TechArt - 20mm and the H&R(Champion) 1-1.25 inches(when I spoke with Champion).
I like the 1-1.25 inch drop but the problem is some people have reported that its too short of a spring and it is not as compliant in the ride as the TechArts. Although H&R has been around the block for a while now and they usually produce a very good product and don't half *** the spring rates/design.
I am waiting for the Bilstein PSS9's to come out but its only showing up in the Euro market right now from what I have read. Nothing here yet.
I just want to see where the price point falls because TechArt being $7.5K and the RinSpeed Bilsteins $5.5K.
I have a good connection for Bilsteins so I am waiting to see what price point it will fall into before I decide. The costs of getting springs now is not the problem its the cost of the labor to replace them if I don't like them. Do that twice and you are looking at wasted money.
Old 07-18-2007 | 08:35 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
The Techarts have a higher rate than stock, whereas the H&R/Champion is a softer rate than stock. I chose the Techarts over the H&R's because they are progressive rates (more comfortable) and don't make that coil-binding noise that some H&R's do
Old 07-18-2007 | 09:01 AM
ALPINE_997's Avatar
Eclou - you don't have time to answer. Don't you have some band sawing to do?
Okay techarts it is. I relooked at your drop with the TA's and they look good. I will go with them then.
Old 07-18-2007 | 10:24 AM
terrence's Avatar
H&R have a softer rate? Would that mean that the H&R would actually ride better? I thought the H&R had a higher rate. And I have seen pictures of the Champions and they looked like progressive rate springs. Anybody else can confirm all this info?
Thanks.
Old 07-18-2007 | 10:27 AM
gmoney's Avatar
Spring rates for these guys is like the colonels recipe for his fried chicken - they wont tell ya!
Old 07-18-2007 | 10:35 AM
eclou's Avatar
Fabryce at GMG knows all the rates
Old 07-18-2007 | 10:41 AM
ALPINE_997's Avatar
yeah but he won't release them
I guess the Eibachs are coming 8/15/07 - that are suppose to be better than TechArts?
He said it was something he was working with exclusively with Eibach.
Old 07-18-2007 | 10:45 AM
gmoney's Avatar
Intrax / Hartmann close to GMG has a machine that can measure spring rates. If you $$$ really want to know Im sure he could run it for ya and print it out.
Old 07-18-2007 | 11:03 AM
eclou's Avatar
Fabryce told me the factory spring rates F/R are in the 200/300# range, the Techarts about 300/500#, their new GMG springs will be in the upper 450/600# range.
Old 07-18-2007 | 12:54 PM
cooperlee's Avatar
cooperlee is infamous around these parts
i have cargraphic springs on mine and i got no complaints. Under sport mode, it is just perfect for everyday drving
Old 07-18-2007 | 01:20 PM
M-Funf's Avatar
M-Funf is infamous around these parts
getting techart for my 2008 TT
Old 07-18-2007 | 02:59 PM
Eric523's Avatar
Eric523 is infamous around these parts
Eibach makes the springs for Techart. It is stamped on the springs
Not sure of the rate differences tho
Old 07-18-2007 | 05:50 PM
whomikem's Avatar
How much do the Cargraphics lower the car?
MM
