997tt - 0 Gt500 - 2
#91
Did the Turbo have sport chrono (you see a stopwatch on the dash that sticks up like an ugly wart right in the middle...???)
The way you described it makes it tough for some owners to swallow, he shouldn't have lost THAT badly...
#92
The pulley adds how much HP from stock at the wheels? Are you certain the fuel metering is able to keep up? I would be cautious as the FGT guys have to do some tricks when they change the pulleys - injectors, FPR IIRC. 11.4 is a great time, but that 60ft is amazing.
#93
Speaking of cars which should respond well to modifications, consider the upcoming "Blue Devil" corvette. Even if they keep the weight constant at 3100 lbs, the tuning potential for that car (6.2L S/C V8) is astounding.
#94
The fuel system on the gt500 is good for 750rwhp with a boost a pump. After that we need larger injectors.
I intend to shave at least another .2-.3 off that with no more mods. That was done at my first time out with those mods.
#95
#96
Originally Posted by dgussin1
Not sure where you're getting your FGT information, but their stock fuel system is good for 900+rwhp with nothing being changed. After that, all they have to do is upgrade injectors.
#97
So just a higher volume fuel pump or FPR keeps the system ok up to 750rwhp? That must mean the stock injectors are run at only 50% duty cycles at WOT at the stock trim?
take a look here to see how a boost a pump works. http://www.kennebell.net/accessories...boostapump.htm
#99
pretty sweet, like a rising rate FPR without the reliability issues! Do you run a wideband or EGT in your car?
#100
It would be insane if they put a lower compression forged piston in there along with a forged/billet rod. It will be the car to beat on the road for sure, too bad they aren't going to make many. IMO it's a true threat to the veyron right out of the box.
Regardless, my order's been in for quite a while.
#102
Originally Posted by spyder997s
Here's the BEST Mustang vs Porsche race I've seen:
http://video.google.com/url?docid=35...85JxB8Hb3h9eVw
that is got to be the funniest video ever.
#104
Damn dgussin1, you sure riled some people up in here. Pullied GT500 and dgussin's driving FTW!
Better bask in the glow of victory while you can though. You know when I'm done with the "Streets" video (remember, the one that shows O-Ace's modded TT911 flying up on you after you initially pulled out two cars), the Porsche guys here are gonna be able to give you a little flak. Until you get the KB that is.
Shank, check our local board for tonight's spot. You can bring the new Porsche (I didn't realize you had a new one until yesterday) and try to rough up Dave down Mexico way.
#105
