Track impressions : Techart springs, Gt3 alignment
I finally got to the track this morning to try out the following mods - Techart lowering springs on the stock dampeners, Gt3 street alignment. Tires used are 18" Hoosier R6 at 40/44 hot front/rear. Temps 75F, and car has stage II GIAC/AWE engine mods, running 100 octane fuel. I have run the same car with the same mods previously but without the springs and alignment, so I have a basis for comparison. Also, car was run in Sport mode with sport PASM on and also PSM left on.
Handling wise, car is tightened up considerably. There is no understeer/push whatsoever. The nose turns in quickly and sharply. The rear end also is much more planted without feeling loose in high speed turns. I have a bad habit of making mid-corner corrections instead of marking the turn and steering with the throttle. The suspension never feels unsettled no matter the surface imperfections. No more pogo over rough transitions. The progressive rate Techart springs also don't feel overly harsh and there is never any bottoming out. This is the most planted and secure feeling car I have ever been on track with, and that includes my dedicated race/track car. There is a tremendous amount of feedback in your butt that is available now that the car feels more settled. The only thing that I would try to improve is the body lean. There is still just a touch much of it, and stiffer sways may help. AWE sells adjustable H&R's for the car, and GMG has adjustable Eibach's coming.
Power wise, I have to say that the GIAC in Race mode with 100 octane is simply a very sick and surreal experience. In street mode sometimes I would get a slight boost tail-off or timing retardation near redline. There is none now. Oil temps never got over 210F, and water temps were dead center. Boost was constantly at 18#, and I am hitting an easy 165mph before the end of the front straight at TWS. Considering that my exit from turn 15 is less than perfect, that the car would be even faster in 50F weather, and that I am too chicken so I brake hard at the end of the straight, downshift to 4th prior to turning into turn #1, I think 170mph at the end is easily possible. As far as I know, even the Cup cars can only hit 160mph at the end of the straight.
Some laps from today:
http://video.google.com/videoplay?do...31244060&hl=en
chrisn,
the street comfort is BETTER than stock, due to the fact the Techart springs are progressive rate and not linear rate springs. I drive almost always in sport suspension mode now, whereas it was too painful with the stock springs
Looks like a great time! What were your lap times? We used to use TWS for the National Supra Meet in March but have gone to MSR Houston the last two years... Thinking about going back to TWS in 08.
Peter
Peter
Duffy, I would check with your local PCA who should have a comprehensive list of track events in your area. PCA runs great driver's ed like in the video with great instructors. It is the BEST mod you will ever do - modding your own skill levels as a driver!
Peter, best lap was 1:58.4, and I'm driving perhaps at 7/10's. The car should be good for sub 1:50's with a driver who has some talent and ballz. I need to talk to you this week about setting up an informal Houston are Porsche tech session or something. The local Motul rep wants to also meet you guys at RSI.
As Eclou suggested, join the PCA. I believe there is an event coming up at Pocono - right in your backyard.
Except for about 2 years in the mid 80's, I've been a member of the PCA since 1979. Just never active. Probably missed out on a lot of great events, both social & driving, in 28 years. Pocono is a little far but BeaveRun is only about an hour from me.
