KW Hydraulic Lift System Coilover Kits 997TT
Contact me for Special 6speed Pricing.
Do you want to drive your car super low around town but have a problem getting into your driveway or over those super big speed ups? For those are always concerned about ride height you can now run your car looking like a race car and comfortably park it in your driveway without fear of scraping up that $100K plus front end.
KW Suspension has their HLS coilovers available in 2 different models for the Porsche 997TT. HLS stands for, Hydraulic Lift System. Like a Lambo, when you press the switch, the car will raise in a range of 30mm to 45mm to give you that extra needed ground clearance. The HLS 2 kit works with the Front Suspension only while the HLS 4 Kit will raise all 4 corners.
Instead of running wires through the car, the system can be activated by a keychain transmitter. The car can be raised and lower while in motion without fear of damaging the vehicle. Their is a hydraulic cylinder between the spring perch and shock body which allows the car to change ride height. The cylinder features rubber bushings for long term durability. The pump can be installed in the spare tire area to offer a clean and functional look.
This kit has been tested on many different Porsche cars throughout Europe and even track tested with great success.
View all the KW Coilover Applications for Porsche Here - http://www.vividracing.com/catalog/s...?filter_id=236
Finally we finish the installation of the KW HLS,works very nice but,I don’t know if this is normal:
If I raise the suspension height it goes up no prob but after 8-10 secs you hear a little click in the compressor area and the car goes down.This is normal ? I thought you can raise the suspension and keep the hi position and drive around and when you reach some speed the car will auto lower but mine lowers after 8-10 sec at any speed.
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
PelicanParts.com
930 Turbo Vendor Classifieds
08-18-2015 04:01 PM
