Vivid Racing ECU Flashes ON SPECIAL Save 20% - Read Here
SPECIAL PRICING good till July 31, 2009!
997 Carrera ECU Flash - Retail $995. Your Price $795
All ECU Flashes receive the following: Raise Rev Limiter 500rpm, increase O2 variables to not throw CEL on high flow cats or catless exhausts, option to add Sport Mode feature or have on all the time, retain original map for easy loading back to stock.
***Add the $150 OBDII Flash Cable or $400 Durametric Diagnostic/Flash Cable or mail your ECU in for no additional charge.***
ECU FLASHING IS EASY FROM YOUR HOME - http://www.vividracing.com/catalog/p...?cID=10&pID=64
Vivid Racing has exclusively used Vivid Racing ECU tuning for several years to power our cars. With some of the fastest Porsche's running Vivid RacingECU tuning, you should too. Having worked with the likes of Jerry Seinfield, Jay Leno, and Hendrick Motorsports, Softronic has an extensive background in Bosch ECU tuning.
The Vivid Racing ECU flash on the 997 Carrera will give you BETTER throttle response, improved low end torque and mid range power, as well as pull harder on the top end. This ECU flash is designed to improve the OVERALL power curve and give you improved driveability.
Vivid Racing tunes give you the best tune the first time. No need for switching maps for race gas, exhausts, or intakes... We can do tunes for 91, 93 octane, or for our international customers, 98ron.
Want proof? We Tune, Test, and Prove at our Arizona facility on our Mustang AWD Dyno.
Either I am dense or your syntax is bad.
Can I get the Durametric cable included in the $795?
...***Add the $150 OBDII Flash Cable or $400 Durametric Diagnostic/Flash Cable or mail your ECU in for no additional charge.***...
Dang it!
Dang - and I just spent 200$ more than that from Scott directly. Great deal @ $795 - and for those on the fence, it was worth every penny!
What is my opinion on EVOMS??? I have no opinion on them or their business which warrants a conversation.
What I can say is what I send in the original post. Softronic has been around longer then most of the Porsche tuners. As an official support person for the PCA Technical board, Softronic has tuned many of the fastests Porsches. They have also worked with and in professional motorsports. The product is flawless and as you can see by the links I put in the original post, the product satisfies customers to the fullest!
