GT Design Introduces Works Bell Aftermarket Steering Wheel Hardware
Looking for a True Plug & Play hardware to accommodate aftermarket Steering Wheel options? We wanted to make that task easier for the 6SpeedOnline community by introducing a company by the name of Works Bell. Certainly no strangers to the racing & tuning community. Works Bell has an array of products from Short/ Standard steering wheel hubs, Quick Releases, and Fold Up Releases for most Japanese and European applications.
Works Bell units are COMPLETE KITS that require zero splicing or tapping into existing OEM wire interface. Air Bag Resistors included and Horn is 100% functioning. 100% Plug & Play, out Project 997S took less than an hour to mount and align EVERYTHING.
PM us if you have any inquiries or questions regarding the setup and we can always put a custom package together for you with a list of Aftermarket Steering Wheel Companies.
Works Bell Short Hub
"Works Bell has developed an exclusive short hub system that is designed for the specific use with the Rapfix II. This short hub system is designed to compensate for the additional length of the Rapfix II and prevents setting the steering wheel too close to the driver. With the short hub system, the user is able to offset the position of the steering wheel anywhere from 20mm-30mm (depending on the hub used) AWAY from the driver for optimum driver position.
These short hub kits are available in application specific models for Subaru, Toyota, Nissan, Mazda, Mitsubishi, Suzuki, and various European models."
Works Bell Rapfix II
"The Work Bell Rapfix II has been a very popular model in Japan due to its convinience and reliability which suits Japanese automobile inspection.
The product was designed to meet the following conditions:
- Must not be shaky when it is set on the steering wheel. - There is no mistake in attachment if you install it at an angle without attention. - You can attach or detach horn wiring and steering wheel at one-step with one button. - Has color variations to choose a color as you like. - In the summer, the body would be heated by direct sunlight and may burn when touched
Besides these features, the RapFix II has one-step attach and detach and weight reduction. Weight is 516g."
Works Bell Short Hub 997 Specific (btw S stands for "short") + Works Bell
Installing on Project 997 (Less than Hour TOPS)
Completed Install !
Your choice of any aftermarket steering wheel, Project 997 opted for a little bit of Italian Flavor with the Personal Grinita 330mm Leather Steering Wheel
-GT Design
Completed Install !
-GT Design
