Gas Tank Won't Fill Up All The Way
Depending on the gas station, the filler at the pump shuts off a couple of gallons short of a full tank. Happens consistantly at certain stations and not at all at others. Even removing the nozzle, waiting a few seconds, reinstalling and then running the pump real slow, still doesn't fill all the way. Anyone else having this issue?
Michael
Michael
It seems to be something that happens on most cars.. isn't the whole process of filling the tank entirely full called "topping-off" ??
If thats the case, I do this all the time when I am on a long trip.. it helps to wait a while and pump slowly until it stops then repeate. eventually you will overflow the tank which is not cool and can damage your paint so you get an idea of when you should stop.
The shape of your gas tank can result in better or worse issues. Some people actually rock their car a little to get the fuel to settle and fuel some more.
