Cold Air Intake
#31
The coupler worked great. Be forewarned though, the Install process is total PITA. Cutting the hole was bad enough but then removing the ALT to get to the oil filler pipe is challenging. I ended up removing the plenum too. The ALT is a very tight fit space wise and tolerance wise to the mount.
