Anyone using a lightweight battery?
Dave
Here's where you get the correct light weight batteries.
The company is Odyssey.
They do batteries right.
When my Interstate MTP-91 quits (it's been in 1.5 years) I am going to an Odyssey. It saves about 20-25 lbs.
As the wise man said 25 lbs here, 25 lbs there, it starts to add up after a while.
http://www.odysseybatteries.com/dealers/california.htm
If you are at the track/autocross, or know you will be in a drag race, remove your spare tire, tool kit, floor mats - you will notice the difference right away. Also a couple threads on 996 board on Odyssey batteries with pics if you do a search.
Dave
spare tire???
I know nothing about Braille but do know that many of the Ferrari guys have gone to the Odyssey with very good results.
There is about a 20 lb difference from the OEM FIAAM battery. Had I known of this battery 2 years ago when I changed mine I would have gone to the Odyssey.
Since I keep my car on a tender I would say my Interstate will now last a very long time. So my assumption is that it will be some time before I change out that battery.
I'll dove-tail Gcalo.......I have Odysee 928s in two 996s......mount below & other pics on my site.
(I'm not trolling on this board....rather 'learning' as I have an in-bound FL997 )
Originally I did it as part of weight loss on the tracking Turbo but these are good bats. I guess the 997 may have more power sucking stuff but I'd think you should be OK...... If the car is not driven for more than a week I plug in the tender (but I used to do that anyway).
OE batt on 996 was 51 lbs.....Optima Red 38lbs, Odyssey1200 38lbs, Odyssey928 26lbs.
Remove the Rear Seats, the Backs and the Bottoms weight about 25-30lbs and are totally useless IMO.
Another way to loose 25lbs is Weight Watchers, take it off your own ***!
I don't think that many of us are good enough drivers to take advantage of a small weight savings like this.
