What tire pressure with 305's in rear.
Old 08-17-2008 | 06:02 AM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Passenger wieght
Originally Posted by keninirvine
Good advice. The door jamb label has a note that says the (higher) pressures shown on the label are for a fully loaded car, and that the pressures shown in manual should be used if weight of driver and passenger etc is less than 352 pounds.
If drive and passenger weigh much more than 352 lbs. it's time to buy a Cayenne.
Old 08-17-2008 | 02:45 PM
MichaelL's Avatar
MichaelL is infamous around these partsMichaelL is infamous around these parts
There is a reason for running the higher tire pressures, they provide more protection for the wheels in normal street driving. One good pothole or depressed manhole cover taken at speed can ruin a wheel. Lower the pressures for track or autocross.
Be aware also that running over a road hazard can "burp" the tire, lower its pressure and make it much more vulnerable to the next hit.
Old 08-17-2008 | 03:12 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
Originally Posted by MichaelL
--- higher tire pressures--provide more protection for the wheels in normal street driving. One good pothole --- can ruin a wheel. Lower the pressures for track or autocross.
---running over a road hazard can "burp" the tire, lower its pressure and make it much more vulnerable to the next hit.
Great points I had not considered but are you referring to 19" or 20" rims or both, please.
RallyBird
10-07-2015 01:20 PM
horsepowerfarm
09-10-2015 06:09 PM
The Oss
08-24-2015 08:19 PM
Zero911
08-24-2015 06:51 PM
Fallbangskid
08-21-2015 02:35 PM
Quick Reply: What tire pressure with 305's in rear.
