HID fog lights
HID fog lights
Has anyone tried putting in actual HID conversions for the fog lights, not the HOEN stuff, actual HIDs. Does anyone know if it will melt the housing, is their space for the ballast behind the bumper?
Check with these folks:
http://www.xtralights.com/index.asp?...WPROD&ProdID=8
I had another link but it's no longer working.
I was thinking of doing this too- The kits with the new digital ballasts and correct bulb size are cheap. Several good ones on ebay or downtown LA in the car stereo electronics district. Shouldn't be hard, just need to tap power for the ballasts and mount them somewhere secure. Bulbs should fit right in the existing socket.
Sounds like a good Saturday project
I asked the same question to a VW mechanic that works on my Touareg. He told me that the factory wiring harness is not sufficent to handle the voltage that the aftermarket lighting system requires.
If you switch the systems it could melt your wires.
You might want to ask him what he really means.
Xenon brightness is based upon the Kelvin scale. The optimum value for car lighting is about 5,000 Kelvin. It yields the cleanest light.
If you go much higher you then start getting a "blueish" color which takes you out of range.
As to wiring, it and of itself should not be an issue. You have to make sure, though, that the socket can tolerate the higher heat of the xenon bulb.
Check with the suppliers to discover what they do for the sockets. If they say OEM is ok be somewhat leary!
If the bulb draws more than 35watts, you are always running the risk of pulling more current through the stock wires than it can handle, thus putting the wires/harness at risk of melting. Also, if it is a low quality ballast, it could be drawing additional "phantom current" that creeps above the marked wattage as well.
That said though, you could always just get the kits with the optional wires that tap power from the battery directly. Some kits even come with them.
hmm, that's not entirely true.. it also depends on the wattage of the HID bulb itself and the quality of the kits and its ballast. I think that's the issue that NorthVan's mechanic is referring to.
Your confusing brightness, which is measured in candles, and light color or temperature, which is measured in degree's Kelvin.
5000 degrees Kelvin is about the same lighting temperature as natural daylight.
My reference was to cleanliness of light with proper color balance.
Xenon lights will NOT melt the housing as it only comsumes 35 w compared to a halgoen bulb 55w or higher. I did this with my old e55, they now have credit card sized ballast that can be easily hidden somewhere. It is possible
