SmartTop Convertible Help
I need helps. I have a smarttop installed a few months back and it was working property. Yesterday I took it out and I brought the car to the dealer to adjust the latch so the convertible top would latch properly.
Anyhow, I installed the smart top module back and tested openning the top down. It worked ok but by the time I got home, it didn't work. While driving there is an error displayed in the intrument cluster saying that the comvertible module error. the key remote works fine with sound and all. Does anyone know what is wrong? How do I manually open the soft top and inspect the smart top?
Thank you in advance.
Alan
Alan
Soft top
I need helps. I have a smart top installed a few months back and it was working property. Yesterday I took it out and I brought the car to the dealer to adjust the latch so the convertible top would latch properly.
Anyhow, I installed the smart top module back and tested opening the top down. It worked OK but by the time I got home, it didn't work. While driving there is an error displayed in the instrument cluster saying that the convertible module error. the key remote works fine with sound and all. Does anyone know what is wrong? How do I manually open the soft top and inspect the smart top?
Alan
Alan
Before opening the top manually try to correct the the Smarttop as follows:
1. Put the Smarttop into Workshop/Diagnose Mode (Mode 1, setting 0) and then turn it back on again, see your instruction manual.
2. Disconnect the battery and leave the car for 30 mins and reconnect, don’t close the hood with the battery connected. You will have ABS and TPS errors on startup but they will clear after about 20-30 mins of driving and a restart.
3. If these fail then you have to open the top manually. After reading the manual I am not sure that if you open the top manually that you will be able to recluse without a visit to the dealer. The Smarttop is probably not broken but the internal “state machine” is probably hung up.
In future just put the Smarttop in Workshop/Diagnose mode before a visit to your friendly dealer.
Good luck. I had a Smart top system fail catastrophically, with the top unable to go up and the horn blowing until the battery was disconnected. Fortunate that there was no damage to the car. The manufacturer was unapologetic and uncaring. I was out of pocket for installation, removal, two way shipping and several days use of the car. The worst experience I ever had with an aftermarket supplier. I have not received even a simple apology from them to this day, two years later. Do business with them at your own risk.
bluebonepc- +1 on Martin's advice. Just use workshop / passthrough mode - no need to uninstall. I just took my car in for top service last week, put it in workshop mode, no issue.
You may want to check the plug and be sure you have it on the pins correctly. It is very easy to accidentally put it one set of pins off.
Either that or it may not be completely seated in the socket.
Thank you for great advices, this board is fantastic. Apparently [FONT='Calibri','sans-serif']smarttop was out of the socket, therefore the connections were interrupted. Dadio, thank you for the tip on instructions to manually raise the top.[/FONT]
ECS Tuning - BMW
10-01-2015 01:35 PM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
ECS Tuning - BMW
09-30-2015 01:08 PM
